number of removable body bushings? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 10-07-2017, 02:00 PM Thread Starter
Quoted: 33 Post(s)
I'm about to separate the body and frame on a 72 lemans convertible (yes I've prepared braces for it). I see there are seven body bushings per side. I only see where six have removable bolts. Do the ones above the rear frame rail area not have bolts that are to be removed? I can see the rubber, but don't see a bolt from above or below that bushing. I was thinking it has a bolt impregnated into the rubber and it screws into the nut in the body.
tjs72goat is offline
post #2 of 4 (permalink) Old 10-07-2017, 02:39 PM
On a convert or wagon, there are 6 bushing/bolts on each side with the dummy cushion inboard above the rear wheel house. All bolt heads will be 5/8" & there are 3 different factory body bolt lengths, the shortest are position 3, right aft of the front seatbelt retractors.
On 2 door hardtops & 2 door Coupes, originally, there are only 5 bolt through body bushings on each side. Up front, inboard, there is a dummy cushion under the cowl, that is the difference. Have upgraded that position to bolt through body bushing on several A-body's.
post #3 of 4 (permalink) Old 10-07-2017, 03:36 PM
Quoted: 391 Post(s)
tjs: "Do the ones above the rear frame rail area not have bolts that are to be removed? I can see the rubber, but don't see a bolt from above or below that bushing."
PJ: No bolts. These rubber bushings are solid and are just laid into the hole in the frame and the body set on top of them.
post #4 of 4 (permalink) Old 10-08-2017, 10:07 AM Thread Starter
Quoted: 33 Post(s)
Thank you. I didn't want to oversee something and have a problem during the separation process.
Body mount bushings orelog 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 8 11-08-2015 08:56 AM
Body bushings question GTO4UNME 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 10-05-2014 10:47 AM
Replacing Body Bushings peahrens 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 01-24-2011 09:05 PM
Body Bushings ChromeShopJoe 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-06-2009 02:32 PM
69 GTO Body Bushings WillieF 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 05-06-2008 06:16 AM
