Numbers above engine code??? - Pontiac GTO Forum
 1Likes
  • 1 Post By Pinion head
post #1 of 3 (permalink) Old 03-12-2017, 04:59 PM Thread Starter
0171953 is stamped above YS. what do those numbers mean? thanks for any info. New to site, just bought 1969 GTO.
Freebird911 is offline
post #2 of 3 (permalink) Old 03-12-2017, 08:48 PM
pjw1967's Avatar
Should be the engine unit number. Do you have the PHS docs? If the nbr on the docs matches the nbr on the block, then you would have part of the "numbers matching" scenario.
pjw1967 is offline
post #3 of 3 (permalink) Old 03-12-2017, 09:16 PM
unfortunately, the invoice copy provided by PHS will not include the Assembly Number aka engine unit number. From some Pontiac assembly plants plants for '67 models, a partial Asm Number is indicated. Similar deal in early '68. After that, this number never makes it onto an invoice. '69 400-2bbl optioned GTO's are an odd case, the economy engine doesnt always show up as an option on the invoice. The 400 2bbl was only avail with its own specific two letter ID code Turbo 400 & typically have a very high ratio rearend gear...2.78's.
pjw1967 likes this.
Numbers over engine code? Freebird911 1964-1974 Tempest, Lemans & GTO General Discussion 1 02-14-2017 11:30 PM
engine numbers Mike Oshinski 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 2 08-17-2015 04:04 PM
Engine code numbers Duckodb Engine Discussions 1 12-17-2014 07:30 AM
Engine Code Numbers V8's Tom L 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 1 08-01-2013 08:46 PM
