odd fitting - Pontiac GTO Forum
post #1 of 5 (permalink) Old 06-14-2014, 06:05 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
odd fitting
Masking up to paint my motor and came across this plug that was barely tight (below and behind the oil filter bracket)...........cautiousy l slid a screw driver and it went in a couple inches! Any idea what it is?
thanks as always
Tk
Topkat is offline
post #2 of 5 (permalink) Old 06-14-2014, 09:19 PM
Icefan71's Avatar
Coolant drain plug?
Icefan71 is offline
post #3 of 5 (permalink) Old 06-15-2014, 10:30 AM
Quoted: 118 Post(s)
Block drain plug, as stated. At least I think so!
post #4 of 5 (permalink) Old 06-15-2014, 10:54 AM
Correct; coolant drain plug. There is one on each side.
younggto is offline
post #5 of 5 (permalink) Old 06-15-2014, 01:09 PM
I agree and your machine shop probably pulled it when they hot tanked your block and replaced the freeze plugs. Put a little pipe sealant on both of the plugs (NOT tape) and snug them up good. Good thing you checked it TC!
Odd Rattle chuckha62 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 16 09-27-2012 03:27 PM
Gas leak. This is odd..... 68greengoat 1964-1974 Tempest, Lemans & GTO General Discussion 5 04-07-2012 08:20 PM
Saw something odd the other day Pontiacpurebrred 1964-1974 Tempest, Lemans & GTO General Discussion 14 03-08-2012 07:52 AM
Odd Introduction thirdcoast Member Introductions 2 02-22-2009 05:29 PM
