Oil for 69 400 - Pontiac GTO Forum
post #1 of 4 (permalink) Old 08-19-2013, 07:00 PM Thread Starter
Oil for 69 400
hey my car that should be arriving around the beginning of sept. It is a 400ci GTO motor. I was wondering what grade motor oil it takes and can I use synthetic?
Darth Menace is offline
post #2 of 4 (permalink) Old 08-19-2013, 09:58 PM
leeklm's Avatar
Most oils out there are marketed to make the owner feel good, and the engine does not really care, at least within reason. From all of the research I have done on the topic, I would run a 10w30 or 10w40 that is advertised with high zinc content, or run whatever oil is on sale and use the money saved on a good zinc additive package.
Or if you have a roller cam, run whatever you run in the minivan or suv in a 10w30, zinc additive not needed.
leeklm is offline
post #3 of 4 (permalink) Old 08-21-2013, 03:52 PM
Zinc is key. I'm lucky, I have a supply of old oil and I run that. Valvoline Racing oil is good for our motors, though. Straight 20, 20w/30, 10w30 all work IF you have zinc. I would skip a zinc additive though. I attended a seminar on oil and the presenter said zinc additive packages are snake oil. Then again, he was selling something else, so... ???
InjunRAIV is offline
post #4 of 4 (permalink) Old 08-21-2013, 04:37 PM Thread Starter
thanks for the info guys. I think i wil use the Amsoil z-rod 10w40. I use the Amsoil z-rod in my viper and I have no complaints. I live close to the distribution centre so i can get Amsoil for cheaper than any other brand name oil in stores. and it takes 5 quarts right?
Oil Pressure - 1974 - 400 GTOKID64 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 05-03-2012 01:10 PM
69 XH 400 pushing oil Backup 1964-1974 Tempest, Lemans & GTO General Discussion 6 01-09-2011 09:32 AM
400 cu running temp/ oil pressure? djn789 1964-1974 Tempest, Lemans & GTO General Discussion 4 07-15-2010 08:29 PM
oil type for 70 ys 400 even steven 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 07-06-2009 01:05 PM
'67 400 Oil Pan Gasket install jesserettele 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-24-2008 03:26 PM
