oil filler cap location - Pontiac GTO Forum
post #1 of 14 (permalink) Old 03-13-2013, 07:46 PM Thread Starter
Hope someone can help me determine which side of the car that the oil filler cap goes on. I have seen them on different sides. Was told yesterday that it was on the passenger side originally but to put it on the drivers side. Its a 389 tri-pwr, no a/c.
mcguiremcd is offline
post #2 of 14 (permalink) Old 03-13-2013, 08:23 PM
67GTOCoupe's Avatar
With the tri-power 389 engine the oil filler cap should be on the passenger side of the engine. I can see no advantage myself to relocating it to the left side unless someone here knows of any particular reason?
67GTOCoupe is offline
post #3 of 14 (permalink) Old 03-13-2013, 09:49 PM
Butchman's Avatar
I agree with 67GTOCoupe. Every one I've seen are on the Passenger side.
1967 GTO, 400 RamAir, 4-speed, Frame off, Quasar Blue Metallic, Edelbrock Performer Manifold, 650 Quick Fuel Carb., Pertronics Electronic Ignition, Crager S/S Mags.
WNY Pontiac ( POCI Member)
GTOAA Member
USMC- oorah
Butchman is offline
post #4 of 14 (permalink) Old 03-14-2013, 06:15 AM
rickm's Avatar
Quoted: 5 Post(s)
if you look closely at the design of the rocker cover, you will see it mounts on the passenger side.
rickm is offline
post #5 of 14 (permalink) Old 03-14-2013, 08:27 AM
Roger that's Avatar
Oil filler caps for the 64/65 389s (and other engines those years)are always passenger side. 1966 GTOs are always driver's side.
Roger that is offline
post #6 of 14 (permalink) Old 03-14-2013, 09:17 AM
Quoted: 98 Post(s)
Roger That nailed it. Depends on the year of the car. I just learned that about a month ago....the valve covers have been "wrong" on my '65 for over 30 years because I referred to the '66 GTO when I installed them!
post #7 of 14 (permalink) Old 03-14-2013, 03:02 PM
rickm's Avatar
Quoted: 5 Post(s)
from '64 thru '66, the " bump " in the rocker cover is never behind the alternator.
rickm is offline
post #8 of 14 (permalink) Old 03-14-2013, 05:46 PM
67GTOCoupe's Avatar
Thats the way I read it. With the appearance of the Q-jet in 67 the tri-power set up disappeared from the option sheet and with good reason. The single 4bbl Q-jet out performed the tri-power set up in every single way.
With this new carb also came the new valve cover design which moved the oil filler to the driver side valve cover.
The GM parts book shows 64-66 covers the same for the V-8 then 67-70 V-8 Pontiac V-8 engines being the same.
post #9 of 14 (permalink) Old 03-14-2013, 08:47 PM
Roger that's Avatar
I just have to add to your comment in where you say "the Q-jet out performed the tri-pwr set up in every single way"; well that will always be debatable but one thing the Q jet didn't beat the tri-pwr in was in the looks department. Tri-pwr is just way too intimidating looking.
post #10 of 14 (permalink) Old 03-15-2013, 06:09 AM
rickm's Avatar
Quoted: 5 Post(s)
i agree with you on that. in the late '70s when i had my '64 bobcat, wherever i went with that car everyone wanted to see the "three deuces". i opened the hood more times than the drivers side door. haha. i does look awsome...
rickm is offline
filler panels 66-67 66goatframeoff 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 11-15-2011 09:08 AM
68 GTO BUmper Filler Dean75181 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 3 06-26-2010 10:54 AM
Rt Rr Shock & Filler Tube pags20 Drive train, suspension, alignment and brakes. 5 02-28-2010 11:00 AM
69 bumper filler? shelbina 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 4 01-14-2010 10:19 PM
Tri-Power Radiator filler neck location VettenGoat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 04-04-2009 10:47 AM
