oil filter bracket - Pontiac GTO Forum
post #1 of 6 (permalink) Old 01-16-2011, 04:23 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
oil filter bracket
2 questions.
What's with the spring & the piece above it?
And what's the groove on the mating surface of the filter for?
thanks as always!!!!!
ID:	10106   Click image for larger version
Topkat is offline
post #2 of 6 (permalink) Old 01-16-2011, 04:34 PM
Quoted: 117 Post(s)
Pressure relief spring in case oil filter gets plugged, so you still get oil flow. That groove should not be there and is a guaranteed leak waiting to happen. Get another unit.
post #3 of 6 (permalink) Old 01-16-2011, 07:51 PM
Topkat, that housing is toast. Especially if you're going to run headers. That leak will drip down right onto the collectors and is guaranteed to cause a fire. (Ask me how I know) I wouldn't risk it even with factory manifolds and head pipes. Get ready for a shock though, those housings aren't available from GM any longer and the aftermarket/repro folks know it.
post #4 of 6 (permalink) Old 01-16-2011, 10:35 PM
66tempestGT's Avatar
if it was mine i would clean that groove with laquer thinner then fill it with a little jb weld and file it smooth.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
post #5 of 6 (permalink) Old 01-17-2011, 12:47 PM Thread Starter
Topkat's Avatar
When I removed the screw from the inside of the housing there is a spring under the plate. under the spring a round disc that covers the hole, underneith the disk was some broken pieces of.......something(at the end of the spin tight.
These bits of "debri" seem to be some sort of almost clear plastic!!!!
any ideas?
is the hole under the disc supposed to be closed completely?
Can I just leave out the spring and the disc?
Seems like some else to cause trouble.
thanks as always
ID:	10108   Click image for larger version
ID:	10109   Click image for larger version
Topkat is offline
post #6 of 6 (permalink) Old 01-17-2011, 01:04 PM
The white nylon bits look like it came from the timing gears. Originally they were covered in nylon to suppress noise.
After you clean everything up put it back together like you found it. Use locktite on the threads of the screw.
dimitri is offline
$200 oil filter DAH GTO Service, Maintenance and Technical Discussion 7 12-25-2006 12:16 AM
Oil Filter GTO-Quikls2 Service, Maintenance and Technical Discussion 12 05-07-2006 09:37 PM
What size oil filter HotRodGuy Service, Maintenance and Technical Discussion 3 02-21-2006 05:38 PM
oil filter? stangeater Service, Maintenance and Technical Discussion 11 01-27-2006 08:17 PM
Long Oil Filter Xman Service, Maintenance and Technical Discussion 0 01-03-2005 09:37 PM
