oil leak - Pontiac GTO Forum
post #1 of 3 (permalink) Old 06-09-2012, 06:43 PM Thread Starter
oil leak
Just bought a 64 lemans 326 2bl 3 speed mt. Drove it 10 miles came home let car set not running, went back to car and sounded like a hose blew,open hood, lots of smoke,steam but no coolant leak, just oil,on air cleaner, valve cover on top and ac compressor.Now oil on top of oil filter running down on exhaust pipe. Dont understand all the noise and where all the oil came from on top . Anybody have any answers HELP.
64lemans is offline
post #2 of 3 (permalink) Old 06-09-2012, 07:50 PM
jmt455's Avatar
Could be a number of things....pics would be helpful.
Are you sure it's engine oil and not A/C refrigerant? There is oil in the refrigerant and it makes a mess when you blow a line...
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #3 of 3 (permalink) Old 06-09-2012, 08:25 PM Thread Starter
Went out and looked and hoses look okay but looking closer found the seal blown on the rear air compessor case, not the o ring for the tubes but the case. This explains why there was oil on the top of the valve cover and air cleaner and the a/c quit working just before that. Never saw a seal blow there before. This explains the noise, it was under pressure. Now I have two problems, a/c compessor and engine oil leak, which is just typical. I never thought abought a/c. Thank you for your help.
64lemans is offline
Gas leak. This is odd..... 68greengoat 1964-1974 Tempest, Lemans & GTO General Discussion 5 04-07-2012 08:20 PM
A/C leak... Poncho Dan Service, Maintenance and Technical Discussion 2 06-04-2011 03:00 PM
leak 04blueskys Drive train, suspension, alignment and brakes. 1 03-20-2011 02:33 PM
LS2 Oil Leak pags20 Engine Discussions 11 10-11-2010 02:01 PM
Oil Leak SLVR DOG 2004-2006 GTO General Discussion 1 02-01-2007 11:13 AM
