oil pan & tc cover - Pontiac GTO Forum
post #1 of 4 (permalink) Old 06-10-2014, 06:06 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
oil pan & tc cover
Can I put the oil pan on and THEN the tc cover of should I do them at the same time? This was many brain cells ago.
Thanks as always
Tk
Topkat is offline
post #2 of 4 (permalink) Old 06-11-2014, 12:05 PM
Quoted: 117 Post(s)
Yes, that's the way I always do it. Use a little RTV in the corners where the timing cover meets the pan. And install the new crank seal in the cover before you install the cover....easier on the bench.
post #3 of 4 (permalink) Old 06-12-2014, 07:19 PM Thread Starter
Topkat's Avatar
Should I use assembly lube on the inside of the tc cover /crank seal?
Also, I cant find the torque specs for the oil pan to tc cover bolts. the books says 12 lbs for the pan to block.....the aluminum tc cover makes me nervous and I sure don't want to strip the threads
thanks as always
Tk
Topkat is offline
post #4 of 4 (permalink) Old 06-13-2014, 09:11 AM
Quoted: 117 Post(s)
12 foot pounds? You're likely to bend the pan and cause leaks...that's too tight. Use a 3" long short ratchet, or a 1/4" drive ratchet, and turn the bolts snug. If you start to pull the pan lip in, and squeeze the gasket out, you are too tight. Tighten just to the point where the pan lip wants to pull in....about 7 ft. lbs, max. Use wheel bearing grease or engine oil on the lip of the crank seal. I use wheel bearing grease or vaseline. Not much, either.
Oil pan cover gasket number Giacobazzi Engine Discussions 0 10-29-2012 07:20 PM
Timing cover first? or oil pan? supercab78 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 11-26-2011 11:22 AM
Oil pan cover removal-reduces rigidity? enjracing Drive train, suspension, alignment and brakes. 8 06-23-2006 10:48 PM
Oil pan cover question. enjracing Drive train, suspension, alignment and brakes. 5 06-13-2006 09:52 AM
