Oil pressure sender issue - Pontiac GTO Forum
post #1 of 4 (permalink) Old 10-17-2010, 09:33 PM Thread Starter
I have a 1966 GTO. The pressure sender is connected to the oil filter housing with a 45 degree brass fitting. The engine has about 100 miles on overhaul. When I accelerate rapidly (less than 4K rpm) the brass fitting keeps breaking and lets oil blow out of the oil filter housing. I thought the brassd fitting might be too tight but the last replacement, I only tightened to little more than hand tight and still it blew/broke. The oil pressure seems to be unusually high, > 60psi. Could that be causing the problem or something else. Thanks. hdeanl
hdeanl is offline
post #2 of 4 (permalink) Old 10-18-2010, 08:43 AM
Sounds like a motor moving, sender hitting something, problem.....60psi is like nothing for a GOOD brass fitting!
Eric Animal is offline
post #3 of 4 (permalink) Old 10-18-2010, 09:12 AM
Quoted: 118 Post(s)
I agree. It would take thousands of psi pressure to break a brass fitting itself. Check for broken motor mounts, etc. Have someone rev the engine while you look at the fitting to see what's going on.
post #4 of 4 (permalink) Old 10-18-2010, 10:36 AM
Can you remove the fitting and screw the sending unit dirrectly into the filter adapter?
why no oil pressure guage? Jeffs386 Interior Discussions 9 07-27-2011 01:53 AM
05 W/ 4L65e pressure issue? pags20 Drive train, suspension, alignment and brakes. 4 12-30-2009 05:00 PM
no oil pressure wingnutooa 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 19 02-14-2009 01:52 PM
Oil Pressure sensors asshauler 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 08-30-2008 06:58 AM
Oil Pressure Gauge stl_head Service, Maintenance and Technical Discussion 6 03-02-2005 06:14 PM
