oil pump - Pontiac GTO Forum
post #1 of 6 (permalink) Old 01-26-2011, 07:53 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
oil pump
does the oil pump to block gasket need to be "glued"?
Thanks as always
Topkat is offline
post #2 of 6 (permalink) Old 01-26-2011, 09:02 AM
Quoted: 118 Post(s)
No, it doesn't.
post #3 of 6 (permalink) Old 01-26-2011, 01:15 PM
Use grade 8 bolts and red locktite on the bolts torque to 30 ft lbs. I thought you already put your pan on?
dimitri is offline
post #4 of 6 (permalink) Old 01-26-2011, 04:10 PM
Dmitri,
Agreed, Gr. 8s, 30 lbs. No need for LocTite, though.
If one is "insecure" about the pump staying in place, you could use studs and NyLock nuts. We don't see an issue here with bolts coming loose.
FWIW
Jim
Mr. P-Body is offline
post #5 of 6 (permalink) Old 01-27-2011, 01:04 PM
Might wanna consider tack welding the screen to the pump after checking clearance though, have seen a couple fall off the pump.
post #6 of 6 (permalink) Old 03-06-2011, 12:42 AM
only tack weld if ball check is out of pump body. better to use tool to install screen into pump body. Tool sold by Mellings. Blue loctite or safety wire when racing.
pontiac is offline
oil pump dilema Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 1 01-13-2011 06:25 PM
correct oil pump? Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 1 11-05-2010 08:07 AM
oil pump? Pontiachris 1964-1974 Tempest, Lemans & GTO General Discussion 11 03-06-2010 11:22 AM
Oil Pump Richtenb Service, Maintenance and Technical Discussion 5 02-15-2010 01:04 AM
05 Oil Pump GTOGuy Service, Maintenance and Technical Discussion 1 09-22-2005 09:02 AM
