oil pump dilema - Pontiac GTO Forum
post #1 of 2 (permalink) Old 01-13-2011, 05:49 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
oil pump dilema
On my oil pump, the press in part of the screen tube is too dam short and will hit the pump.
In the pics it is barely started and is a 1/4'' from hitting the pump but needs to go in another 3/8"
I called Melling and they told me ya normally press it in with the pickup over the top of the bottom of the pump
(if that makes sence)
Then it will hit the bottom of the pan..........
The pick up cannot be pressed in below the level of the bottom of the pump as it would hit the rods caps.
what's the deal?
thanks as always
ID:	10049   Click image for larger version
ID:	10050   Click image for larger version
Topkat is offline
post #2 of 2 (permalink) Old 01-13-2011, 06:25 PM
Go to Melling's web site. There is a video on how to properly set the gap of the bottom of the oil pan to the pick up tube screen.
Use Gr 8 bolts on the pump with red locktite torqued to 30 ft lbs.
Don't forget to put the shaft in first. The short end, dippled part of the shaft is at the top of the engine when it is sitting upright.
dimitri is offline
oil pump failure imminate? ride400 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 21 12-02-2010 10:46 AM
correct oil pump? Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 1 11-05-2010 08:07 AM
oil pump? Pontiachris 1964-1974 Tempest, Lemans & GTO General Discussion 11 03-06-2010 11:22 AM
Oil Pump Richtenb Service, Maintenance and Technical Discussion 5 02-15-2010 01:04 AM
05 Oil Pump GTOGuy Service, Maintenance and Technical Discussion 1 09-22-2005 09:02 AM
