?opening up hood scoops? - Pontiac GTO Forum
post #1 of 2 (permalink) Old 07-10-2009, 09:29 AM Thread Starter
I was able to get ahold of a ram air pan off a 68 gto to put on my 69. I would rather open up my own scoops rather than pay 150+ for opened plastic scoops thru ames or OPG. Any suggestions on teh best way to do this? I don't want to ruin the finish on mine that match the paint. Please advise
clarkaim is offline
post #2 of 2 (permalink) Old 07-10-2009, 10:18 AM
Quoted: 98 Post(s)
I've done several, and it's easy. The one's I did were for '65-'67, but it should be the same. You need a die grinder and a cut-off wheel. You take the die grinder, and make several light passes along the BACK side of the scoop openings, with the wheel PERPENDICULAR to the scoop back. Takes about 5 minutes, and you'll still have the "grille" inside the scoop intact. Looks trick, better than cut all the way open, and keeps the locusts out.
Functional Hood Scoops on 05 no rice 2004-2006 GTO General Discussion 29 04-10-2005 08:41 AM
05 hood scoops - rain, snow in engine? taylor65 2004-2006 GTO General Discussion 5 01-22-2005 04:38 PM
04 w/ hood scoops and dual exhaust fireitupgto 2004-2006 GTO General Discussion 0 12-22-2004 10:17 PM
real hood scoops?? cr125 2004-2006 GTO General Discussion 2 09-15-2004 10:09 AM
