Opinions appreciated - Pontiac GTO Forum
post #1 of 14 (permalink) Old 03-27-2013, 03:04 PM Thread Starter
EVERS3's Avatar
My 67 is numbers matching, front to rear, and as far as I can tell has never had any major engine work, such as a rebuild, etc.
It has developed a few leaks (rear main seal), etc. and I have decided that if I am going to continue to drive it on a weekly basis that it is time to make a move on it.
My research shows that the costs will be relatively equal (+/- a few hundred $$$) either way, and my options are:
1) Pull the motor and send it off to a machine shop such as Central Virginia Machine where it will be rebuilt from the ground up, dished pistons, new rods, valve train, etc.to bring it up to modern specs inside, while maintaining the original heads, manifolds, carb, etc. and original look, outside.
2) Pull the motor, put it into storage, and install another motor with all of the modern bells and whistles, aluminum heads, manifold, new carb, etc. for weekend driving fun, retaining the original motor, in original condition, to be passed on to a new owner should I ever decide to sell the car.
I would appreciate anyone's opinion(s) regarding the Pros and Cons of either option above.
EVERS3 is offline
post #2 of 14 (permalink) Old 03-27-2013, 03:19 PM
rickm's Avatar
Quoted: 5 Post(s)
you only live once...
rickm is offline
post #3 of 14 (permalink) Old 03-27-2013, 03:55 PM
If it were me and the costs came out the same, I'd restore the original. It'll be fast, sound good and when someone asks,"What you got under the hood?", the answer is all that more impressive. If you want better performance, you can always change intake/carb and headers while retaining the originals on a shelf for later and it's still numbers matching. Just my humble opinion as a numbers matching '69 Goat owner.
1969 GTO
Numbers matching 400 c.i.d.
Numbers matching TH400 w/stage 2 shift kit
Limited slip 3.23 gears
2 1/2 inch dual exhaust all the way back
Dual gate shifter out of a '68
Cragar Protech rims
etewald is offline
post #4 of 14 (permalink) Old 03-27-2013, 03:58 PM
If I had endless pockets I'd do a Built Blown Butler motor.
post #5 of 14 (permalink) Old 03-27-2013, 04:32 PM
Quoted: 105 Post(s)
It's really up to you....what do you want? I have the original drivetrain in my '67, and several years ago installed lower compression Pontiac heads. That enabled me to drive the car on pump gas. 2 years ago, I pulled the engine for a reseal job, and it was cheap and effective, as I did all the labor myself with a friend helping out. Not a big deal. I had rebuilt the engine in 1988, and it had about 75,000 miles on the rebuild, so just a reseal was needed. As a side note, it didn't really need a rebuild in '88...it just had 2 burnt valves. If I knew then what I know now, I would have done the heads and left the rest alone. Bear on this forum did exactly what you're thinking with his #'s correct '69 GTO....he did a Jim Lehert 461 stroker, and has a 500HP street machine that is capable of 11 second 1/4 mile times. His car is a monster, and that's how he likes it. It's really up to you and what you want to do with the end product...do you want a street terror or a cruiser?
post #6 of 14 (permalink) Old 03-27-2013, 04:50 PM Thread Starter
EVERS3's Avatar
I'm really wanting to end up with the same product either way, a strong street machine that will go hard if I want and stand up to a little abuse while maintaining sanity at the stop sign, and reasonable RPM levels (gas mileage) on the highway.
Jim at Central Virginia Machine has a package that he calls the "400 Pontiac Restoration" that would satisfy the need.
I guess what it really comes down to is whether or not rebuilding an "original" motor internally to modern specs. will diminish the value of the car down the road?
EVERS3 is offline
post #7 of 14 (permalink) Old 03-27-2013, 05:02 PM
Sir, it sounds like "numbers matching" is a feature that is important to you. Option 1 sounds best for you. Or a third option of only fixing what needs attention, as Geeteeohguy mentions. Much more affordable as well. Matt
Matthew is offline
post #8 of 14 (permalink) Old 03-27-2013, 06:07 PM
Quoted: 105 Post(s)
Rebuilding the original engine to modern specs will not diminish the value of the car, particularly if it's just dished pistons and a cam. If you go for a full blown stroker, you will lose potential value if you sell it, and you will sacrifice street manners and mpg. I even went as far as installing a highway geared rear end in mine (shelving the oem unit) and enjoy over 20mpg at 75mph on the highway. That, as well as being able to run on pump gas, has me driving the '67 a lot more than my '65, which is still the original high compression and needs race gas. The main thing in keeping value is keeping the original block with the car at sale time. My big question is how many miles on your engine? If under 150,000, and it runs well, I would not rebuild it. I'd pull and reseal and think about some garden variety lower compression heads with about a 90cc chamber. If you do decide to go the rebuild route, Jim is 'the man' and the first choice IMO to do the job.
post #9 of 14 (permalink) Old 03-27-2013, 06:14 PM
Quoted: 105 Post(s)
I forgot to add, and this is very important, that when you upgrade your engine power significantly, you will have to upgrade everything else: rear end, trans, brakes, suspension, etc. Putting a monster motor into a bone stock chassis is asking for parts breakage and possible safety issues. Look at Bear's threads and see what he did with his 461: new rear end, brakes, suspension, trans, etc. $$$, but bulletproof and safe to drive. He also gets decent mpg for his HP: about 15, if I remember correctly.
post #10 of 14 (permalink) Old 03-27-2013, 06:46 PM Thread Starter
EVERS3's Avatar
Excellent info Geeteeohguy. Best I can tell the speedo on my car is about to roll for the second time (approx. 197,000 mi.), so a rebuild is probably in order.
From the input to this point, I think I'm going to be sending the motor to Virginia.
When I spoke to Jim he indicated that his "400 Pontiac Restoration" package would likely only increase the hp to somewhere in the 375 range (only 40 more than stock) while maintaining all of the original exterior parts (heads, intake, carb, etc.) and making the entire package much stronger from a reliability standpoint, so I'm thinking that the stock Turbo Hydramatic and 3:36 rear will still handle the package. May have to upgrade to a modern torque converter though.
EVERS3 is offline
Trunk access. Any help appreciated pykes04goat 2004-2006 GTO General Discussion 11 04-10-2011 02:20 PM
Auto shifter issue... Any help appreciated... crazzymann Interior Discussions 6 03-23-2011 03:41 PM
gto needs some more power! help much appreciated 71goate 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 08-04-2010 02:29 PM
I need some help/opinions chad.fear Engine Discussions 5 05-13-2010 05:17 AM
