Opinions on my dilemma - Pontiac GTO Forum
post #1 of 19 (permalink) Old 03-08-2013, 01:46 PM Thread Starter
Here is my dilemma. I need a little bit of work done to 71.I know the owner of Griffin and sons. He told me he would charge me $75hr, but there are 2 hot rod shops in the area that want $50hr. Should I go with who I know and trust won't try to nickel and dime which is the most expensive or the unknown cheaper shops? Who would you go with?
psilentchild is offline
post #2 of 19 (permalink) Old 03-08-2013, 06:52 PM
gotyorgoat's Avatar
I would get a written estimate and schedule from each. Hours can add up fast depending on how they allocate their time.
It doesn't have nitrous. It has cubic inches.
gotyorgoat is offline
post #3 of 19 (permalink) Old 03-08-2013, 07:54 PM
05GTO is offline
post #4 of 19 (permalink) Old 03-08-2013, 09:28 PM
then take estimates to the shop you choose. Don't be afraid to ask for references from other customers from those shops. They should'nt have any problem giving you customer references either.
post #5 of 19 (permalink) Old 03-08-2013, 11:48 PM
FlambeauHO's Avatar
Quoted: 8 Post(s)
Re: Opinions on my dilemma
Really depends on your budget, You truly can't put a price on a trusted shop doing the work right the first time.
FlambeauHO is offline
post #6 of 19 (permalink) Old 03-09-2013, 12:12 PM Thread Starter
That's the thing. I only have $500 to spend. I was told I need a tune up along with a new distributors.
post #7 of 19 (permalink) Old 03-09-2013, 01:41 PM
Here is a DUI from Summit for $305 + some parts store wires and a set of plugs you are under $400.
This is easy stuff, do it yourself, save some money and learn something.
Typical "garage" if you tell em' you've got $500 to spend it'll either be $499 or $599 lol and you'll be lucky to get the plugs, wires and cap and rotor installed for that.
post #8 of 19 (permalink) Old 03-09-2013, 02:36 PM Thread Starter
Does it matter which wire I use? I was thinking about changing the plugs and wires myself . I was going to take 1 wire off change the plug put on the new wire follow the old wire, then replace the old with the new on the other end. Is that right?
post #9 of 19 (permalink) Old 03-09-2013, 03:56 PM
That will work. I would say any 8mm wire would be fine, try to avoid the Chinese junk make sure it is Made in USA for quality, there is a difference.
This may help you too......
http://bangshift.com/blog/chart-of-c...rtesy-msd.html
Name:	Pontiac V8 Firing Order.jpg
post #10 of 19 (permalink) Old 03-09-2013, 06:37 PM Thread Starter
Cool. I have points on there now and I was told I need to get rid of them. How do I go about doing that? Do I just remove the old distributor and replace it was the new one?
69-GTO Tire/Rim Dilemma... rvp986 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 02-10-2013 10:47 PM
Sort Of In A Dilemma?Any Advice slik 2004-2006 GTO General Discussion 4 12-02-2011 07:04 AM
Engine "non-start" dilemma The Patchwork Tiger 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 7 11-05-2010 09:19 PM
I need some help/opinions chad.fear Engine Discussions 5 05-13-2010 05:17 AM
Dilemma with my dogs! Help! sharkbite1979 The Lounge 14 08-16-2006 07:17 PM
