over heat at shutdown - Pontiac GTO Forum
post #1 of 7 (permalink) Old 02-22-2016, 04:07 PM Thread Starter
my 69 gto 400 is a fresh rebuild less than 500 miles on the complete rebuild. the car runs a little hot but does not discharge any coolant until i shut the car off and then it blows off a lot of coolant. new pump, new radiator, shroud covers the fan, the hoses are new and not collasped. i would appreciate any thoughts or other help. timing seems to be right on
kensoldgoat is offline
post #2 of 7 (permalink) Old 02-22-2016, 04:32 PM
Quoted: 106 Post(s)
What is a little hot temp wise?
Rebuilt engines will run a little hot for the first 5-8 hundred miles.
Make sure you have a good cap and don't overfill the radiator, leave a couple of inches or it will spit some out.
Goat Roper is offline
post #3 of 7 (permalink) Old 02-22-2016, 06:20 PM
Start by checking the radiator cap. what psi is it? The cap is often overlooked.
70kgold is offline
post #4 of 7 (permalink) Old 02-22-2016, 06:36 PM
Lemans guy's Avatar
Quoted: 70 Post(s)
I agree with the guys, pressure cap keeps the boiling temp down, bad cap will make the car run hotter, but even if right overfilling the radiator will cause a car to overflow even if all is correct, correct fan couch operation also overlooked and causes it to run hot at idle, then it gets hot and hard to cool off...also correc 50 x50 antifreeze mix is the best...
Lemans guy is offline
post #5 of 7 (permalink) Old 02-24-2016, 09:36 AM
Quoted: 118 Post(s)
What these gents said. New engines run a tad hotter, an over-filled radiator will puke when heat soaked due to no room for expanding coolant, and a weak cap will let it puke that much easier. It's amazing how many 15 pound radiator caps open up at about 7-8 psi!
post #6 of 7 (permalink) Old 02-24-2016, 10:25 AM
If there is no overflow tank the level should be about 2 inches below plum full when cold.
post #7 of 7 (permalink) Old 02-25-2016, 05:52 PM
Layzdude's Avatar
Second that. Had the same issue with my 68. Replaced the cap and all is well.
Layzdude is offline
Full Electrical Shutdown & reboot Russ2005 Service, Maintenance and Technical Discussion 7 03-02-2014 07:38 PM
No heat or a/c Goat_power Service, Maintenance and Technical Discussion 2 08-01-2013 04:51 PM
No a/c or heat TxSoldier6.0 Service, Maintenance and Technical Discussion 3 06-22-2011 09:26 AM
Key doesnt come out of ignition after shutdown Lunceford34 Interior Discussions 7 09-21-2010 11:47 AM
Light show shutdown indefinately............. johnebgoode 2004-2006 GTO General Discussion 10 12-13-2005 06:52 AM
