painless harness quirk - Pontiac GTO Forum
post #1 of 4 (permalink) Old 06-05-2011, 08:54 PM Thread Starter
crustysack's Avatar
not sure if this is correct forum but-- I rewired my car with a painless 18 circuit wire harness- I wired the electric cooling fans directly into the hot accessory on the fuse box. My horn shorted out and my gauge lights would not light. I think the draw was to high and screwed the wiring adjacent to the hot accs. outlet on the fuse panel. I have switched it so the signal from the fuse panel goes to a relay. seems to have fixed the problem
crustysack is offline
post #2 of 4 (permalink) Old 06-05-2011, 09:09 PM
jetstang's Avatar
I feel every high amp draw circuit should go through a relay and not the fuse box. Sounds like you fixed the problem.
Sweet car by the way!!
Burning rubber since 1982!!
jetstang is offline
post #3 of 4 (permalink) Old 06-06-2011, 09:46 PM
electric fans draw a lot of juice...especially when they start up....I've been told to run a 40A relay....Eric
Eric Animal is offline
post #4 of 4 (permalink) Old 06-06-2011, 11:33 PM
correct, fan circuit is separate, not connected through fuse panel. as mentioned, separate relay and fuses \ circuit breakers.
pontiac is offline
wiriing harness olde-goat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 6 12-22-2010 04:35 AM
3-point harness?? MoGoThnSho 2004-2006 GTO General Discussion 14 08-25-2010 03:05 PM
engine harness ? zzomby 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 10-30-2009 11:17 PM
Headlamp Harness PEKO Service, Maintenance and Technical Discussion 2 11-05-2007 01:51 PM
wiring harness fastcars Service, Maintenance and Technical Discussion 0 01-04-2005 02:03 PM
