painting ex manifold - Pontiac GTO Forum
post #1 of 4 (permalink) Old 02-13-2011, 05:09 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
Got my Plastikote Iron gray paint.
should I not paint the coil on the flapper valve?
thanks
Topkat is offline
post #2 of 4 (permalink) Old 02-13-2011, 10:17 AM
chuckha62's Avatar
Quoted: 18 Post(s)
Have you painted them already? If not, take a look at Calyx Manifold dressing. Calyx is the right product for exhaust manifolds, paint isn't.
chuckha62 is offline
post #3 of 4 (permalink) Old 02-13-2011, 05:33 PM
Don't paint the coil. As far as paint goes, it really does not matter what you use. They all burn off and rust. Ceramic Coating is the only coating that will last. This has to be professionaly applied. The bad thing about this is your heads will look like crap at the exhaust ports and your exhaust manifolds look nice and painted. After about 1,000 miles all of the paint is burned off your heads on the exhaust side and is rusting.
dimitri is offline
post #4 of 4 (permalink) Old 02-13-2011, 06:35 PM
chuckha62's Avatar
Quoted: 18 Post(s)
Dimitri, we should get together, I'm in Santa Rosa.
Now, I respectfully disagree with using paint on your manifolds. I've had too many hod rods to count and I can say without reservation that painting the exhaust is the wrong way to go about it, plain and simple! The BEST way, bar-none is the Calyx manifold dressing! Try it, you will not be disappointed!
painting ex. manifold Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 3 02-09-2011 08:53 AM
painting pulleys Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 8 12-08-2010 04:07 PM
painting alternator Topkat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 12-04-2010 12:51 PM
Painting bolts Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 10-24-2010 05:22 PM
Painting Radiator olde-goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-12-2010 09:16 PM
