Parts list for Hideaways? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 04-23-2012, 06:41 PM Thread Starter
Since my 69' is already a clone, I'd like to go further and add hideaways. I've seen the electric motor kits like this on ebay:GTO Hideaway headlight electric door conversion | eBay . Can somebody post a parts list needed in addition to these motors??? Thank you
1969 GTO clone, stock 400 motor and 400TH transmission
pontiacsniper is offline
post #2 of 6 (permalink) Old 04-24-2012, 09:45 AM
Pontiacpurebrred's Avatar
First you need completely different bumper brackets. They are currently not reproduced and are rather difficult to find. (And can be pricy if you do find them)
You will need the headlight buckets and door assembly.
And a few other small parts. You won't need the vacuum components if you are going electric.
Here's a couple of pictures for reference.
2005 GTO Daily Driver
1969 Custom-S Project car
1971 GTO 455 in process of rebuild TH400 NEED A NEW REAREND!!!
Pontiacpurebrred is offline
post #3 of 6 (permalink) Old 04-24-2012, 05:17 PM
If you have an endura bumper you won't need the different brackets for the hideaways. The brackets you have will have the proper holes for a stock setup and you are going aftermarket anyway. I fabbed up my own electric setup and it was pretty simple really and way cheaper.
I have both and chose to run the non hideaway brackets because they are lighter. My car originally had hideaways but when I bought a different endura bumper from a fixed headlight car it had the different brackets.
post #4 of 6 (permalink) Old 04-25-2012, 08:54 AM
Really??
I had always heard and been told the standard brackets interfere with the headlight doors because of how they attach. (wouldn't let them open and close freely)
Well learn something new everyday.
post #5 of 6 (permalink) Old 04-28-2012, 02:13 PM Thread Starter
ok, assuming my brackets will work, I found a set of Hideaway housing assemblies on Ames website for $750 part number B144 and the actuator arms for $89/pr part B147B. Is this all I need besides the actual headlight buckets and the actual outer headlight doors and junkyard door motors??? It seems like piecing this kit together is almost the same as the $1199 vacuum actuated kit from Ames.
post #6 of 6 (permalink) Old 06-06-2015, 04:02 PM
Looking into the same issue you had now, did you ever find a solution?
snoopyg73 is offline
front end parts list? virginiavenom 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 6 02-21-2012 02:55 PM
66 Lemans need Parts list 5.3L swap Oldstech 1964-1974 Tempest, Lemans & GTO General Discussion 7 08-17-2011 07:04 AM
Can anyone help with a list of parts? 1fstGTO23 2004-2006 GTO General Discussion 1 02-19-2011 10:03 PM
My Ames Parts List 5hundo 1964-1974 Tempest, Lemans & GTO General Discussion 4 11-25-2007 09:36 AM
