PCV valve grommet - Pontiac GTO Forum
post #1 of 18 (permalink) Old 08-10-2011, 09:20 PM Thread Starter
SDGoat619's Avatar
PCV valve grommet
Has anyone replaced the PCV valve grommet that is underneath the intake manifold on the engine valley. I just pulled the old one out but it was distroyed, hence my vacume issues with the carb, do I need to remove the intake manifold to POP the new one in there or should I be able to wedge the new one back in the same way
Sent from my PC36100 using AutoGuide App
ID:	11974   Click image for larger version
65 LeMans, 455,TH400, Edelbrock preformer Intake&Carb, K&N Filter, Custom Headers & Dual Exhaust W/ H pipe, 15in ralley wheels...... More to come.
SDGoat619 is offline
post #2 of 18 (permalink) Old 08-11-2011, 11:56 AM
68GTO4004Spd's Avatar
should be able just to push it in with the manifold in place.
68GTO4004Spd is offline
post #3 of 18 (permalink) Old 08-11-2011, 12:16 PM Thread Starter
SDGoat619's Avatar
That's what I figured, I just wanted to double check.
post #4 of 18 (permalink) Old 08-11-2011, 12:28 PM
Quoted: 103 Post(s)
You'll find that the new ones are not rock hard with age and that they push right in place very easily. No worries.
post #5 of 18 (permalink) Old 08-11-2011, 12:37 PM Thread Starter
SDGoat619's Avatar
I had to order it from Ames, should get in today. I was having trouble with my carb struggling under load until WOT. I realized that the grommet was shot and that is why my vaccum was not working right.
post #6 of 18 (permalink) Old 08-11-2011, 01:27 PM
If the new grommet is too tight, a little grease around the lip that pushes in will aid in installation.
post #7 of 18 (permalink) Old 08-11-2011, 06:22 PM
grommet available at better auto stores. Just got two from Napa.
pontiac is offline
post #8 of 18 (permalink) Old 08-11-2011, 08:18 PM
Quoted: 103 Post(s)
A bad PCV grommet will have nothing to do with poor WOT performance: there is no vacuum at WOT.
post #9 of 18 (permalink) Old 08-14-2011, 09:54 AM Thread Starter
SDGoat619's Avatar
My WOT is fine it the initial that falls on its face
post #10 of 18 (permalink) Old 09-17-2011, 11:26 AM
Did the grommet fix your stumble?
68raGTOp is offline
4 hole firewall grommet sixtysix 1964-1974 Tempest, Lemans & GTO General Discussion 1 03-08-2011 06:04 PM
Pcv Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 8 02-01-2011 07:28 AM
66 gto grommet sixtysix 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 09-25-2010 05:24 PM
Pass-through grommet in trunk? Gregscalade Interior Discussions 2 12-28-2006 08:11 PM
