Pertronix - Pontiac GTO Forum
post #1 of 5 (permalink) Old 03-24-2011, 11:13 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
Pertronix
Has anyone installed the Pertronix 2 electronic ignition conversion in their points distributor?
I got the magnetic ring in place and the induction coil and was trying to set the air gap. (ultimately .010)
This is done with washers that are all the same size (lol)
Anyway, the mag ring was wobbling!!!
According to the tech at Summit Raccing, if the thing "wobbles" more than .005" it wont work.
Mine wobbles .012
GRRRRRRRRRRRRRR.........
thanks
Topkat is offline
post #2 of 5 (permalink) Old 03-24-2011, 11:40 AM
68GTO4004Spd's Avatar
I've done it. You have to bend the module slightly to bridge the gap. Be carefull not to break it. Carefully read the instructions (I know it goes against the man code), it explains it pretty well in there. Make sure you shim the drive gear if needed to tighten everything up, and recheck all your gaps before installing.
68GTO4004Spd is offline
post #3 of 5 (permalink) Old 03-24-2011, 01:48 PM Thread Starter
Topkat's Avatar
It seems the mag coil was "bent" like .012'' (the one the rotor mounts to)
the Tech at Summit says it cant be bent (Wobble more than .005'')
calls for a .010 overall clearance.
I love the 8 washers (that are all the same size, to accomplish that)
Also says that the dist "up and down" endplay can't be more than .060.
mine is less.
sent back for exchange.....................
grrrrrrrrrrrrrrr
Topkat is offline
post #4 of 5 (permalink) Old 03-24-2011, 10:34 PM
Ah yes, the joys of aftermarket parts.
post #5 of 5 (permalink) Old 03-24-2011, 10:53 PM
xcmac26's Avatar
Quoted: 5 Post(s)
if i may be so bold...why'd you go for pertronix II when the pertronix III is on the market and is ever so simple to install. hell...i did it
xcmac26 is offline
FINALLY installed my pertronix ignitor III and coil xcmac26 1964-1974 Tempest, Lemans & GTO General Discussion 27 11-16-2010 10:25 PM
Horsepower Gain from Pertronix Ignitor III xcmac26 1964-1974 Tempest, Lemans & GTO General Discussion 21 05-31-2010 06:35 AM
