That pesky chemical - Pontiac GTO Forum
post #1 of 5 (permalink) Old 04-20-2008, 12:30 PM Thread Starter
blondie67's Avatar
That pesky chemical
Hey Randy 05GTO,
I'm going to locate some of that OSPHO chemical you talked about. Where can I find it? Would it be at an auto supply store or do I have to go to a hardware store?
Linda
blondie67 is offline
post #2 of 5 (permalink) Old 04-20-2008, 01:44 PM
Linda,
Try one of these Automotive Paint Suppliers in Washington, I believe there is one in your city.
Be careful, use a resperator and gloves! OSPHO contains phosphoric acid and will blister your skin if it comes in contact with any part of your body.
I only used about 1/2 gallon treating the entire stripped car inside and outside.
05GTO is offline
post #3 of 5 (permalink) Old 04-20-2008, 02:32 PM Thread Starter
blondie67's Avatar
chemical
Hey Randy,
Thanks! One question, should I take out the gas can before using it in the trunk?
Linda
post #4 of 5 (permalink) Old 04-20-2008, 08:15 PM
Yes, I would remove the tank and inspect the trunk and braces from the bottom, the tank is not that hard to remove,
05GTO is offline
post #5 of 5 (permalink) Old 04-21-2008, 08:46 AM
Quoted: 118 Post(s)
Hey, Linda. You probably already know this, but I'll remind you anyway.......remember to neutralize any chemical strippers/acids you use after they do their intended job. Usually the directions with the product will tell you what to use. If not, the MSDS can provide that information. Acids tend to keep right on going! (Don't ask me how I know this!)
You are about to embark on some of the dirtiest, most unpleasant, labor-intensive work on the car. Keep your eyes/body protected and have at it!!!! Way to go. !
Jeff
