Pitman Arm - Pontiac GTO Forum
post #1 of 12 (permalink) Old 04-02-2008, 10:17 PM Thread Starter
Pitman Arm
On An 69, with power steering, is the Pitman arm to be flush with the Powersteering gear box?
POOF is offline
post #2 of 12 (permalink) Old 04-02-2008, 11:24 PM
formerly NJGoat
NJG8GT's Avatar
I don't know the answer to your question, but that is one sweet ride!
Let's Go Cowboys!!!
2009 Pontiac G8 GT Liquid Red, sport & premium pkg, Lloyd floor mats, Pontiac trunk liner, mobil 1 plus Z-Max, VG sharkfin antenna, Volant CAI, Superchips Cortex 93 octane Volant tune, Solo -Performance axle-back exhaust, Solo X pipe, BP-catchcan
NJG8GT is offline
post #3 of 12 (permalink) Old 04-03-2008, 06:57 AM
If you jack the front end off the ground and grab the passenger wheel and try to force it left to right, back and forth, there should be NO up and down movement from the pitman arm. Left to right movement is okay, but any up and down movement means the part is worn out.
*edit*
Da...that`s for the idler arm, not the pitman arm.
/me crawls under a rock
post #4 of 12 (permalink) Old 04-03-2008, 08:53 AM
Quoted: 118 Post(s)
The pitman arm should be all the way on the sector shaft, but not rubbing the body of the gearbox where the sector shaft comes out. There should be a small gap...some cars have a felt dust shield here. The arm should be far enough on the sector shaft so that the shaft protrudes out of the Pitman arm slightly. I've seen worn out drag links, tie rods, etc, but I've yet to see a pitman arm come off a sector shaft easily! Good luck....
Jeff
post #5 of 12 (permalink) Old 04-03-2008, 01:12 PM
Jeff
I have about a 3/8" gap between the top of my pitman arm and the bottom of the gear box.
05GTO is offline
post #6 of 12 (permalink) Old 04-03-2008, 05:00 PM
Quoted: 118 Post(s)
3/8" is right where it should be.
post #7 of 12 (permalink) Old 04-03-2008, 06:38 PM Thread Starter
Thanks for the help. Its on there where the nut is fully on ,but it looks like its about 3/4 to an 1 inch gap.
POOF is offline
post #8 of 12 (permalink) Old 04-03-2008, 07:56 PM
You may be OK, my measurement was taken from my 66 and GM changed the design on the pitman arms in 68.
05GTO is offline
post #9 of 12 (permalink) Old 04-04-2008, 12:19 PM
Quoted: 118 Post(s)
As long as the nut is fully on, you'll be ok. If your sector shaft was coming out of the gearbox (which I've never seen happen) you'd have all kinds of problems tryiing to steer!
Jeff
post #10 of 12 (permalink) Old 04-06-2008, 09:19 AM
I'll check my 67 tonight and post...
Eric Animal is offline
Front and Rear Control Arm bushings 04m6_ca Service, Maintenance and Technical Discussion 1 02-10-2008 01:09 AM
Arm Injury = No Goat GM Kid 2004-2006 GTO General Discussion 10 02-05-2007 06:19 PM
cam Q's GTO6 2004-2006 GTO General Discussion 1 10-18-2006 07:34 PM
Where to get upper control arm bolts? GTO394 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 06-24-2006 06:41 PM
rocker arm ratio ??? flht3 Service, Maintenance and Technical Discussion 7 11-01-2005 09:00 AM
