Plug wire question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-23-2010, 01:10 PM Thread Starter
68GTO4004Spd's Avatar
Plug wire question
I recently installed a set of 8mm Accel plug wires with a straight boot. The one on the 7 cylinder (left rear) is stuffed into the steering shaft. How have you guys gotten around that, different boot, modifications, give me some fresh ideas here, pictures would be cool. Just pickin some brains.
68GTO4004Spd is offline
post #2 of 3 (permalink) Old 09-24-2010, 01:38 PM
Quoted: 118 Post(s)
Don't use a straight boot/end. Use a 45 or a 90 degree boot and end.
post #3 of 3 (permalink) Old 09-24-2010, 03:55 PM
68greengoat's Avatar
I ended up shortening the boot, the end opposite the plug to keep a good fit around the plug, then bending the plug end at a 45deg. It's still close to the steering tho. If I would have known the boot was going to be an issue like yours ahead of time, I would have bought 45deg boots. The straight ones do look cool, IMO. Especially, if you're not into originality..
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
68' ground wire question Lithium 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 09-25-2009 08:41 AM
Tach Wire 66GTO7.5L 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 04-22-2009 11:06 PM
Date coded plug wires and plug question 70gto 1964-1974 Tempest, Lemans & GTO General Discussion 7 09-26-2008 03:25 PM
spark plug question matt68gto 1964-1974 Tempest, Lemans & GTO General Discussion 1 04-27-2006 08:49 AM
