plug wires - Pontiac GTO Forum
post #1 of 8 (permalink) Old 03-31-2011, 10:02 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
plug wires
I have a stock points distributor that im converting to electronics, with Pertronix2, can I use the standard stock cap?
I cant order plug wires till i find out
thanks as always
Topkat is offline
post #2 of 8 (permalink) Old 03-31-2011, 10:26 AM
thanks as always
I don't know why not. The conversion just replaces the points/cam mecanism, right? If it uses the same rotor and distributor body, then a factory style cap would be required.
post #3 of 8 (permalink) Old 03-31-2011, 11:00 AM Thread Starter
Topkat's Avatar
apparently I need to swap my stock cap for and HEI cap, in order to get the spiral core wires needed for the pertronix .
Topkat is offline
post #4 of 8 (permalink) Old 03-31-2011, 11:12 AM
Ummm.... an HEI cap is not going to fit the stock distributor body. The HEI is much larger in diameter. Contact Pertronix tech support and get their recommendations.
post #5 of 8 (permalink) Old 03-31-2011, 11:53 AM
68GTO4004Spd's Avatar
I used Accel Superstock series 4000 8 mm plug wires with the stock cap and Pertronixs II. Works just fine.
68GTO4004Spd is offline
post #6 of 8 (permalink) Old 03-31-2011, 01:12 PM Thread Starter
Topkat's Avatar
Original parts group MSD cap (MSD8433)is supposed to fit " many stock GM points type distributors).............crosses fingers
thanks
Topkat is offline
post #7 of 8 (permalink) Old 04-01-2011, 08:34 AM
68greengoat's Avatar
You can use your stock cap/rotor for all the Pertronix units. I'm using Accel 8.8mm wires with mine.....
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #8 of 8 (permalink) Old 04-01-2011, 09:07 AM
Quoted: 100 Post(s)
Well, all GM V8 engines took the same dist. cap from 1957 thru 1973......you can go from there. Any standard plug wire will be fine, as long as it measures less than 25k ohm resistance per foot of cable. Have fun.
'67 Plug (Ignition) Wires cfredflyu 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 04-26-2010 08:23 AM
Date coded plug wires and plug question 70gto 1964-1974 Tempest, Lemans & GTO General Discussion 7 09-26-2008 03:25 PM
Spark plug wires dizzy1 2004-2006 GTO General Discussion 0 05-08-2007 08:34 AM
taylor plug wires troy hudson Service, Maintenance and Technical Discussion 0 10-08-2006 11:00 AM
Spark Plug Wires Maximental Service, Maintenance and Technical Discussion 4 02-08-2005 11:15 PM
