pontiac 400 block is this junk - Pontiac GTO Forum
post #1 of 6 (permalink) Old 05-25-2013, 10:14 PM Thread Starter
please help was this 400 cast this way or was it damaged ????? any info will help looks like some type of hack job repair
mbspeed is offline
post #2 of 6 (permalink) Old 05-26-2013, 08:03 AM
It's hard to tell from just a photo. Looks like at some point in its past though someone cared enough about it to install studs for the lifter cover instead of using the factory bolts - that's something. If it were me, I'd go ahead and strip the block then take it to a good machine shop to have it cleaned and then magnafluxed to check for any cracks, and get their opinion on it. If you've got a die grinder, go ahead and spend some time knocking off all the sharp edges and removing rough casting flash (like around the outsides of the lifter bosses).
Now would be a good time to pick up a copy of Jim Hand's and/or Rocky Rotella's books about building Pontiacs, if you don't already have them.
How to Build Max-Performance Pontiac V-8s by Jim Hand | 9781884089671 | Paperback | Barnes & Noble
How to Build Max Performance Pontiac V-8s by Rocky Rotella | 9781934709948 | Paperback | Barnes & Noble
post #3 of 6 (permalink) Old 05-26-2013, 11:04 AM
hinged block
That's so strange. Seems I've seen that exact "patch" on another block many years ago. Looked like an old door hinge. I swear I've seen it!...
gjones is offline
post #4 of 6 (permalink) Old 05-26-2013, 12:16 PM Thread Starter
its very strange i was hoping it was a cast like that from GM i dont have the $$$ to send it out i cleaned aera and it looks like part of block it doess not look good ..... maybe it is a one off ram air 6 block I need one of the great pontiac masters to tell what it is
mbspeed is offline
post #5 of 6 (permalink) Old 05-26-2013, 04:04 PM
If I had to guess I'd say they are patches to the forms they used for the original sand casting. Check out this Car Craft pic. Looks kinda familiar.
Pontiac 400 Poncho Engine Build Je Pistons Photo 5
Mr_Roboto is offline
post #6 of 6 (permalink) Old 05-26-2013, 04:34 PM Thread Starter
I can see like a shadow of the same patten thank you for the picture i need to sell this motor dont want to have a problem with a cracked block :
mbspeed is offline
400 block $ question bobby326 1964-1974 Tempest, Lemans & GTO General Discussion 1 12-25-2009 11:24 AM
400 Block Question Ozzmann 1964-1974 Tempest, Lemans & GTO General Discussion 4 10-31-2009 02:41 PM
326 block and 400 block jbranontn 1964-1974 Tempest, Lemans & GTO General Discussion 2 07-18-2009 10:55 AM
