Pontiac 400 Mechanical Oil Pressure Gauge - Pontiac GTO Forum
post #1 of 7 (permalink) Old 07-04-2014, 02:13 PM Thread Starter
jtwoods4's Avatar
Hey guys,
I am trying to install a Mechanical Oil Pressure Gauge on my 1972 400 engine. I want to plumb the gauge into the oil passage that is right next to the distributor. This passage is normally blocked off with a 31/48-inch-diameter pipe plug with a recessed Alan head.
I am having the hardest time finding a gauge that comes with the correct NPT adapters to connect to this location. How the hell do I connect the gauge to this location? If you have done this please tell me the gauge kit you ordered and what NPT adapters you used.
John
jtwoods4 is offline
post #2 of 7 (permalink) Old 07-04-2014, 08:27 PM
Pontiacpurebrred's Avatar
Might be no help at all but I've never seen one plumbed there. I've always plumbed it off the filter housing and that's what I've always seen. Hopefully someone who's more familiar with your request can help.
2005 GTO Daily Driver
1969 Custom-S Project car
1971 GTO 455 in process of rebuild TH400 NEED A NEW REAREND!!!
Pontiacpurebrred is offline
post #3 of 7 (permalink) Old 07-04-2014, 09:06 PM
Quoted: 390 Post(s)
That is where I located mine. Supposed to get a better oil pressure reading. I think I used the fitting that was included -plastic oil line and fitting. I did not have any problems, it screwed right in. Try NAPA autoparts as they sometimes have brass fittings or possibly another line kit. Last resort, email the tech guys at Summit or Jegs and see what they might suggest? It should not be a problem.
post #4 of 7 (permalink) Old 07-10-2014, 05:41 AM
RunninLeMans's Avatar
Me, too, you can use a standard brass tee and nipple off the filter housing if you want to keep the warning light operational.
RunninLeMans is offline
post #5 of 7 (permalink) Old 07-10-2014, 11:20 AM
I too plan on using hooking the mechanical oil pressure gauge near the filter. I just hope I can use a T or something and keep the current electronic gauge working with the mechanical.
VA67GTO is offline
post #6 of 7 (permalink) Old 07-10-2014, 02:57 PM
That's exactly what I did. Easy.
Sent from AutoGuide.com App
MrMootsie is offline
post #7 of 7 (permalink) Old 07-10-2014, 07:57 PM
X 65,000. JT, you'll want to put that as close as possible to the oil pump.
Mechanical oil pressure gauge jumping / Volts Issue tags68 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 07-26-2011 07:37 PM
Oil pressure gauge problem Richie Cat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 10-26-2008 04:16 PM
Oil Pressure Gauge ACR 2004-2006 GTO General Discussion 7 12-03-2006 11:21 AM
Oil Pressure Gauge ? lotaguts Interior Discussions 12 02-10-2006 01:11 PM
Oil Pressure Gauge stl_head Service, Maintenance and Technical Discussion 6 03-02-2005 06:14 PM
