pontiac 400 small block - Pontiac GTO Forum
post #1 of 17 (permalink) Old 08-23-2013, 08:26 PM Thread Starter
Hello there! I am new! My name is Cristian and I am from Orange County, CA!
I bought my 71 nova about 5 years. When I bought it, the seller told me the motor was a Pontiac 400 small block out of a GTO. I knew very little about muscle cars back then and I thought I was buying it for a good deal.
Now im 23 years old and wanting to rebuild the motor yet IDK what I exactly have. I was looking around the block and I saw on the passenger block above headers had some numbers. I also looked under the distributor cap. After doing my research I understood that the 6x heads were never in a GTO to begin with because they started in 77-79. I uploaded two images. Where else should I look on the motor?
The numbers by the passenger side above headers were C306 Then over the last spark plug it was D then N. Also vertically as you can see it is GM3 and horizontally 6X.
Under the distributor cap as you can tell by the picture the numbers are A038.
I googled these numbers and have no luck. Can anyone steer me in the right direction on finding out what I exactly have? Thank you. I really want to build this motor to 300 ponies or more!
ID:	26130   Click image for larger version
QuesoBlanco is offline
post #2 of 17 (permalink) Old 08-23-2013, 08:35 PM
Welcome to the forums!
Check this site...
Pontiac Power
post #3 of 17 (permalink) Old 08-23-2013, 08:45 PM Thread Starter
Appreciate it ill go under my car and look.
post #4 of 17 (permalink) Old 08-23-2013, 09:06 PM
68greengoat's Avatar
The heads are '76. C306 - March 30th, '76
Block is a '68 or '78 - A038 January 3rd '68 or '78. Block casting number would help determine the year...
D and N is the shift - Days/Nights
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #5 of 17 (permalink) Old 08-23-2013, 09:25 PM Thread Starter
Sweet thanks for the info.
On the driver side of the block I saw 6x and also A068.... Vertically it said G M 7. After the A068 to the right it said D and N.
On each head the stamped ID is 8.
post #6 of 17 (permalink) Old 08-23-2013, 09:26 PM Thread Starter
Where is the block casting number ?
post #7 of 17 (permalink) Old 08-23-2013, 09:33 PM Thread Starter
9790071 Wow there it is! I found it!
post #8 of 17 (permalink) Old 08-23-2013, 09:36 PM Thread Starter
So I have a 1968 block with one side 76 head and the other 78?
A068 was driver side head.
C306 was passenger side head.
Weird....
post #9 of 17 (permalink) Old 08-23-2013, 09:45 PM
I would double check the last digit on those heads. 8s can look like 6s and 6s can look like 8s.....
SOLD.....
462ci, 4spd
post #10 of 17 (permalink) Old 08-23-2013, 09:47 PM Thread Starter
I cleaned them up well it is clearly visible that driver side is 8 and passenger side is 6.
pontiac 400 block is this junk mbspeed 1964-1974 Tempest, Lemans & GTO General Discussion 5 05-26-2013 04:34 PM
New small block chevy danfigg 2004-2006 GTO General Discussion 1 01-10-2013 01:37 AM
400 block $ question bobby326 1964-1974 Tempest, Lemans & GTO General Discussion 1 12-25-2009 11:24 AM
326 block and 400 block jbranontn 1964-1974 Tempest, Lemans & GTO General Discussion 2 07-18-2009 10:55 AM
