Pontiac/ chevy dipstick - Pontiac GTO Forum
post #1 of 8 (permalink) Old 01-11-2015, 01:36 PM Thread Starter
bobby326's Avatar
I have oil blowing out my dipstick. It doesnt have the rubber piece on it to snug it on. Can i just use a parts store chevy dipstick or do i need a pontiac specific dipstick
bobby326 is offline
post #2 of 8 (permalink) Old 01-11-2015, 03:37 PM
Is it blowing the dipstick out of the tube? You may have another problem too much pressure in the crankcase. Could be bad rings or you may need better ventilation for the crank case.
post #3 of 8 (permalink) Old 01-11-2015, 04:52 PM Thread Starter
bobby326's Avatar
I checked my pvc valve and it seems to be working. When i blow in it i can hear the check valve ball and i can blow air out. My dip stick doesnt have the rubber in it so it just kinda sits on top of the tube. I just bougt a chevy one so it will seal the dip stick tube and when i need to check my oil ill use the pontiac stick
bobby326 is offline
post #4 of 8 (permalink) Old 01-11-2015, 05:37 PM Thread Starter
bobby326's Avatar
If i have too much crankcase pressure would haveing breathers in the valve covers help. I currently have the finned edelbroock ones with no holes.
bobby326 is offline
post #5 of 8 (permalink) Old 01-12-2015, 08:44 AM
Yes, I recommend running them. Also can you put a seal on your existing dipstick?
post #6 of 8 (permalink) Old 01-12-2015, 01:37 PM Thread Starter
bobby326's Avatar
I'm sure I can rig something up
bobby326 is offline
post #7 of 8 (permalink) Old 01-12-2015, 02:09 PM
How long has this been going on? Like Alky said, bad rings or possibly a head gasket can put too much pressure in your crankcase. Matt
Matthew is offline
post #8 of 8 (permalink) Old 01-12-2015, 05:12 PM
Quoted: 362 Post(s)
The crankcase builds pressure within as the pistons move up and down th cylinders. The faster the engine goes, the more pressure builds up.
You need valve covers with breathers or you may blow out some gaskets as well.
New Pontiac Firebird aka 2011 Chevy Camaro FireBreather trev0006 The Lounge 5 09-20-2013 08:54 AM
Hooker Competition Headers and Pontiac 400 Dipstick jtwoods4 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 02-10-2013 07:31 PM
Get it blown: With Pontiac or Chevy-Engine? VolkerGermany 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 12-22-2011 08:52 AM
73 Pontiac Lemans Sport Dipstick Length oelfkp 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 05-11-2011 08:01 PM
Pontiac Pulleys same as Chevy SB or BB? mighty454 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 07-06-2010 05:58 AM
