Pontiac Hood Tacs - Pontiac GTO Forum
post #1 of 4 (permalink) Old 07-25-2014, 08:01 PM Thread Starter
kilkm68's Avatar
Pontiac Hood Tacs
Anyone have trouble with the Ames hood tachs and HEI distributors? I bought a New one from Ames this spring and have trouble with it sticking at 4k rpms. I called Ames and they said to check the ground. I ran a heavy gauge test wire to a solid ground but didn't help. They said the HEI may cause the problem as they're made for the stock distributors. They said send it in to be checked out, which I will do this fall, I told them I didn't want to drive around all summer with a hole in my hood. I have a DUI distributor. I know MSD has a tach adapter that some cars use. Anyone had this problem or any luck with the adapter?
kilkm68 is offline
post #2 of 4 (permalink) Old 07-25-2014, 08:04 PM
I've also seen issues with the HEI distributers. I think they make some sort of adapter.
post #3 of 4 (permalink) Old 07-27-2014, 03:57 PM
maktope's Avatar
I had an adapter, after looking at it i sent it back, put a relay into a fuse and havent had a problem. My buddy runs the adapter on his 70 gto and no issues. Only thing about my set up is i as rpm increases i get a little off. At idle i am perfect at 2k i am about 50rpm off, at 3k i am 100rpm off and at 5k i am 200 off. Not sure if its because the relay or if its the tach.
maktope is offline
post #4 of 4 (permalink) Old 07-28-2014, 05:37 PM
Quoted: 118 Post(s)
Don't know about the repop tachs, but the oem stuff usually is about 10% too fast. Not super precise.
Pontiac hood latches norwood 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 11-16-2008 11:24 AM
