Is this a Pontiac Tempest Custom - Pontiac GTO Forum
post #1 of 11 (permalink) Old 10-02-2014, 07:33 AM Thread Starter
Ok so Bear and a few other guys have really layed into me on this site
but here we go again ... I have been really trying to ID this car
The VIN 235370B137196
The Pontiac Custom S was a single model year car that was marketed between the Pontiac LeMans and the Pontiac Tempest. For reasons unknown, this one-year only nameplate replaced the previous model years Tempest Custom name in the Pontiac line-up.
The Custom S was only available for the 1969 model year. The car was originally to be called the "Pontiac TC".[1]
It was available in six different body designs: two-door convertible (VIN #'s starting with 23567xxxxx), hardtop coupe (VIN 23537xxxxx), sports coupe
Tell me that Im that Lucky and I got a Tempest Custom with a 400 4barrell
and its value and significance
Pontiac Custom S - Wikipedia, the free encyclopedia
Sixfigures7 is offline
post #2 of 11 (permalink) Old 10-02-2014, 08:25 AM
Roger that's Avatar
If your VIN had the number 9 prior to the letter B you would have a 1969 Custom S hardtop coupe. But since you have a 0 instead, it is a 1970 LeMans Hardtop coupe.
Roger that is offline
post #3 of 11 (permalink) Old 10-02-2014, 09:25 AM
Roger that's Avatar
I just read your other thread with the RAM AIR IV and I think your talking about the same car on this thread.
The 3537 was used in 1969 for the Custom S (pic 1) and the 3537 was also used for the 1970 LeMans (pic 2). These cars have different lines. These pictures should tell you which car you have.
ID:	46729   Click image for larger version
post #4 of 11 (permalink) Old 10-02-2014, 10:54 AM Thread Starter
Roger that , I would like to thank you very much for providing me with such info
Could you provide me with available motor trans options for a 1970 Lemans Hardtop
I would really like to get to the bottom of this mystery
The VIN Identifies the car with a V8 less than 100,000 Units
the car is in the body shop and im dying to get it back so i can look up some of the stampings block head etc
IN the meantime i just would like to know what scenarios could unfold with the motor and trans that could have or did come in this car
post #5 of 11 (permalink) Old 10-02-2014, 11:27 AM
Roger that's Avatar
Info for your car:
post #6 of 11 (permalink) Old 10-02-2014, 04:32 PM
Quoted: 103 Post(s)
Also, be advised that in 1970, the insurance companies were cracking down on musclecars like the GTO. Rates were skyrocketing. A few wise folks went the sleeper route and ordered a T-37 or Custom S or plain Tempest/Lemans with GTO running gear. They got a slightly lighter, faster car than the GTO, and saved a bundle on insurance. Had a friend back in the late '70's with a GT-37 (Or maybe T-37) that had the GTO 400, 4bble, TH400, and 3.23 rear gear. That car was just as fast as the GTO. So, not really far-fetched that a mere Tempest/Lemans of this vintage is packing some serious power from the factory.
post #7 of 11 (permalink) Old 10-02-2014, 09:49 PM Thread Starter
I would like to thank you Gentlemen for taking the time to both answer and inform me as quickly and cordially as you have ...
I will be sure to let you know how it pans out
post #8 of 11 (permalink) Old 10-03-2014, 06:04 AM
Jared's Avatar
Quoted: 5 Post(s)
While you have it in the paint shop see if they can find the build sheet. That would answer all of your questions. My dad ordered a Cutlass S in 1972 that had all of the W-30 suspension parts and a 4 speed (unfortunately he went with a 350). He said you could order everything individually right down to the rear gears. I hope you got really lucky and the numbers or build sheet match up.
Jared is offline
post #9 of 11 (permalink) Old 10-04-2014, 06:46 AM
silversport's Avatar
sometimes found under the rear seat...
Bill
**QSM/RH/A4/17**1 of 52**
silversport is online now
post #10 of 11 (permalink) Old 10-04-2014, 01:24 PM
Jared's Avatar
Quoted: 5 Post(s)
The build sheet can also be found on top of the gas tank. Or in the case of the Cutlass S I was telling about, we bought the car back when the third owner wrecked it and the build sheet was jammed inside of the frame.
Jared is offline
68 tempest custom convertible 475linebaugh Member Introductions 2 04-09-2014 10:24 PM
64 Tempest Custom Restoration dcvice1967 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 11 02-28-2011 08:15 PM
1969 Pontiac Custom S/Tempest turn signal housings Kip Page 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 02-09-2011 04:22 PM
