Posi codes. - Pontiac GTO Forum
post #1 of 3 (permalink) Old 01-12-2010, 10:32 AM Thread Starter
Posi codes.
Hi.
Can anybody advise if the codes "40 13 GM 965 XO" in the rear diff (66 GTO)
bear any relevance to the axle ratio? If so what ratio would they make it. Or are they just factory part stamps.
I am a new member from the UK. (not many goats over here).
Many Thanks.
Gran Turismo is offline
post #2 of 3 (permalink) Old 01-13-2010, 08:59 AM
68greengoat's Avatar
Originally Posted by Gran Turismo View Post
Hi.
Many Thanks.
If it's a true '66 axle, look on the back of the axle tube, passenger side for a "stamped" 2 letter code. Should begin with a w, x, y or z. The x codes were XE, XF, XG and XH. No XO. Could it be an XG? The code will tell you the ratio and whether or not it was a posi.
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #3 of 3 (permalink) Old 01-13-2010, 10:14 PM
gtoearl's Avatar
Quoted: 22 Post(s)
Hi there, I know how frustrating it can be not being able to find answers to questions....you are curious about.......I found this on line....Hope it is helpful.....
http://www.wallaceracing.com/axledata2.htm
gtoearl is offline
question about posi differentials xcmac26 1964-1974 Tempest, Lemans & GTO General Discussion 11 12-21-2009 05:00 PM
69 GTO 10 bolt non-posi convert to 12 bolt posi AzStateFan 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 0 09-12-2009 04:34 PM
posi switch- crustysack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 02-08-2009 07:41 PM
Posi? THEHERDER 2004-2006 GTO General Discussion 16 02-24-2007 02:45 PM
Posi-track Vedli 2004-2006 GTO General Discussion 27 11-10-2005 05:00 PM
