Power source to horn relay? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 05-02-2012, 11:20 AM Thread Starter
rwhitaker's Avatar
Looks like my 67 GTO has had some creative wiring along the way. Horn relay power lead connects to alternator and provides only 1-2 volts output to relay, 3-4 volts after starting. I have seen a diagram which indicates power comes from a junction box. Can anyone tell me which one and where it is located, what it looks like? Thanks!
rwhitaker is offline
post #2 of 6 (permalink) Old 05-02-2012, 12:35 PM
RIP (12/27/60-7/18/15)
Topkat's Avatar
Hi. I have a 67 Goat as well. I believe mine goes thru the firewall, thru one of the 2 plugs on the drivers side of the eng compt. Pretty sure it goes to the rear of the fuse panel.
not 100% sure
good luck
Topkat is offline
post #3 of 6 (permalink) Old 05-02-2012, 01:25 PM Thread Starter
rwhitaker's Avatar
That's the green trigger wire that goes from the horn button to the relay. Fortunately, I know that works because the relay clicks. But there is not enough current to engage the horns. So that has to be a power source problem, I think. Somebody let me know if I'm off base here. Thanks.
post #4 of 6 (permalink) Old 05-02-2012, 04:00 PM
3 wires involved. 1 green= trigger for relay, from firewall/fuse panel. 2 black = power to the horns, from the relay. 3 brown = power into the relay, from the fusable link (alternator). The horns MUST also have a very good ground to the vertical brace...what goes in (+) ...must come out (-). Eric
Eric Animal is offline
post #5 of 6 (permalink) Old 05-03-2012, 08:23 AM Thread Starter
rwhitaker's Avatar
Good information. Glad I don't have to go re-routing to a junction box. Thanks!
post #6 of 6 (permalink) Old 05-03-2012, 09:24 AM
No problem! If you want a really good wiring diagram for your car go to Classic Car Wiring . Com : Home of the original color laminated car wiring diagram for about $15 you will get a clear, colored, lamanated diagram. Eric
bad horn relay Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 2 05-06-2011 05:45 AM
horn relay Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 1 05-02-2011 05:58 PM
64 Horn Relay? Al T 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 08-25-2010 05:15 PM
Horn Relay xcmac26 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 12-09-2008 02:47 PM
