Pricing for changing gear ratio - Pontiac GTO Forum
post #1 of 13 (permalink) Old 06-09-2009, 10:54 AM Thread Starter
xconcepts's Avatar
Looking at changing up my ratio for the 66 from a 2.56 to 3.08. I have the original rear axel with the 3.56 but seems thats a little high for highway speeds. Anyone know a rough estimate on how much changing up the ratio?
xconcepts is offline
post #2 of 13 (permalink) Old 06-09-2009, 10:59 AM
Check with Randy`s ring and pinion, the best prices out there and great service.
I run 3.55s with a 4-speed and 15" rear tires and it runs down the road great.
post #3 of 13 (permalink) Old 06-17-2009, 02:44 AM
while yall are on the subject my tempest has 2.56 none posi rea but with the roads around here id liek to have posi but i wish to keep the 2.56 geaing but all the posi chunks for the 10 bolt rears have a ange of gearing listed thay will work with, the only 2.56 posi i have found is a full sized posi chunk out of a late 60's to mid 70's car, will it fit my 66 10 bolt? or were would i find what im looking for?
danthepontiacman is offline
post #4 of 13 (permalink) Old 06-17-2009, 07:26 AM
Call Randy's Ring and Pinion and ask them what to run. They will have the answers your looking for.
post #5 of 13 (permalink) Old 06-17-2009, 11:59 AM
Jim
Jim's Avatar
The 2.56 gearing uses a series 3 carrier. It will support all the way up to 3.23's. Anything above the 3.23's uses a series 4 carrier.
I would think what you have will fit but I'm with Rukee. Call the pro's !!!
Good Luck
Jim
Jim is offline
post #6 of 13 (permalink) Old 06-17-2009, 12:10 PM
Quoted: 103 Post(s)
The 2.56 is a 2 series carrier. It will support 2.56 and 2.73 gears. The 3 series carrier is 2.93 thru 3.23. The 4 series carrier is 3.36--4.33. Should be fairly easy to find a 2.56--2.73 LSD for your ride. Good luck.
post #7 of 13 (permalink) Old 06-18-2009, 11:24 PM
jetstang's Avatar
You have 2.56 or 3.56 in your car now? I've never heard of a 3.56, heard of 3.36 gears.
Yes, 3.55s pulls more RPM at speed and acts like you need another gear, but the acceleration will offset the RPM. 3.08 or 3.23s are a good compromise gear.
jetstang is offline
post #8 of 13 (permalink) Old 06-18-2009, 11:27 PM
thanks guys, i like the 2.56 geaing but i would liek to have two drive wheels instead of one. aint it great that thares so many repro and aftermarket parts for gm car? and just ahs these cars get old enough to have to be called outdated thay come out with all these aftemarket parts that will insure these cas can be on the road in another 40 years.
post #9 of 13 (permalink) Old 06-20-2009, 12:47 PM Thread Starter
xconcepts's Avatar
There is a 2.56 in there right now but it is not the original. The original I am told is a 3.56 but was switched due to the RPM's. I was looking at getting the one in there now, the non original and switching it to a 3.08 to get more RPM at speed. What would be better ratio to go with 3.08 or 3.23?
post #10 of 13 (permalink) Old 06-20-2009, 08:24 PM
Quoted: 103 Post(s)
Pontiac never offered a 3.56 gear in any A body. It was a 3.55 ratio that was fairly standard on the '65--'67 stickshift cars.
GTO Gear Ratio's geeteeohguy 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 150 03-15-2019 03:10 PM
Computer guages (Autotap OBDII-CAN Diagnostic) MJGTOWISH 2004-2006 GTO General Discussion 3 12-03-2006 10:01 AM
I am looking for the perfect gear ratio. Empaler Drive train, suspension, alignment and brakes. 3 08-11-2006 08:04 PM
rear end gear ratio question matt68gto 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 04-03-2006 10:30 AM
05 GTO vs 04 GTO - 3rd gear pull BLACK05GTO Racing and Kill Forum 2 09-24-2005 05:24 PM
