PS box seal replacement - Pontiac GTO Forum
post #1 of 2 (permalink) Old 01-19-2014, 05:02 PM Thread Starter
Reb
Reb's Avatar
The power steering box of my '67 is leaking badly at the torsion bar seal. Can the seal be replaced by simply removing the steering column, exposing the seal (there is what appears to be a clamp around the shaft in front of it, prying the seal out, and replacing it?
I tried looking for instructions in the factory service manual, but it seems to cover only replacement of the pitman arm seal.
Reb is offline
post #2 of 2 (permalink) Old 01-20-2014, 11:37 AM
Quoted: 118 Post(s)
There are great instructions on line if you poke around. What you want to do, yes, but the problem is it is very easy to cut the new seal up on the splines. There are tricks, like plastic sleeves, tape, etc. so you can get the seal in without tearing it up. I think you mean the input shaft seal. There are no torsion bars on your car except in the trunk!!!
Viton Seal leaked terrible. Installing Graph Tight Seal timmyg 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 07-08-2013 01:17 PM
What is the Right Pinion Seal? Wob 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-30-2012 03:54 PM
Trunk seal? bigrc2 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 8 05-04-2011 06:34 AM
68 Trunk seal Dgto68 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 1 06-17-2010 05:48 PM
Rear main seal replacement tv66 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 10-04-2009 08:17 AM
