PS hoses - Pontiac GTO Forum
post #1 of 7 (permalink) Old 02-24-2011, 11:34 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
PS hoses
Do I need to put teflon tape on my power steering hose connections?
thanks as always
Topkat is offline
post #2 of 7 (permalink) Old 02-24-2011, 12:32 PM
FNG69's Avatar
Didn't use it back in the day. But don't see that it would hurt anything so if you want to do it!! Those flared ends still real tight anyway.
FNG69 is offline
post #3 of 7 (permalink) Old 02-24-2011, 12:41 PM
Quoted: 103 Post(s)
No need for the tape.
post #4 of 7 (permalink) Old 02-24-2011, 02:14 PM
On the high pressure side, the flared end of the fitting provides the seal. Doubtful that teflon tape would be able to seal under that much pressure if the fitting couldn't. On the low pressure side, it's so easy to seal that you don't really need it there.
post #5 of 7 (permalink) Old 02-26-2011, 07:06 PM
Just installed a new set today, no tape or anything else.
post #6 of 7 (permalink) Old 03-05-2011, 11:56 PM
tape will give you a problem you don't need.
pontiac is offline
post #7 of 7 (permalink) Old 03-06-2011, 09:36 AM
!!!! Never use Teflon tape, especially on flaired fittings. If you feel the need to use a sealer, use a liquid teflon coating.
convertible hydraulic hoses xcmac26 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 4 11-22-2010 08:59 AM
64 Radiator Hoses Question Al T 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 08-23-2010 09:59 PM
Windshield Washer Fluid Hoses fell Off sutliffhl21 Service, Maintenance and Technical Discussion 2 06-01-2006 11:06 PM
Check your A/C pressure lines / hoses westell Service, Maintenance and Technical Discussion 0 03-01-2005 04:39 PM
