Quadrajet Q-on '71 GTO, rich idle - Pontiac GTO Forum
post #1 of 3 (permalink) Old 10-07-2010, 04:07 PM Thread Starter
Issue-when my 71 GTO comes off choke at idle it smells very rich & the idle adjust. screws do not seem to do much if anything to help. Once car comes off choke the gas smell out of the exhaust is quite strong, however, I do not see any black smoke. Pulls 10-11 on vacuum in park (best I can remember, need to check again). So far I have adjusted timing & the idle screws, and I drilled a couple holes in the butterflies. None of this had much of an effect.
Last weekend I pulled the top off the carb and verified float is set ok (actually a little low) and noticed that there is no retainer on the power piston??? Also, the power piston dome appears a little beat.
My buddy that is helping me said he has some extra power pistons from Q-jets and most if not all have a prominent tail and retainer. Should I swap out my power piston with one of his, and swap to a lighter spring since my car has a cam & headwork (specs unknown done by PO years ago). Motor is a '71 400 that also has HEI & is otherwise stock. Just seeing if I'm on the right track....
My carb is a 7029268 which I believe is a '69 350/400/428 auto trans 750 cfm.
Other than the rich smelling idle, car seems to run pretty good out on the street...
Thanks!
BlueMonkey is offline
post #2 of 3 (permalink) Old 10-07-2010, 06:23 PM
Sounds like the carb needs a rebuild, and a new set of butterflys. Drilled holes in them...what the heck??
post #3 of 3 (permalink) Old 10-08-2010, 10:53 AM
Jeff's Classics's Avatar
If I recall correctly, drilling one or two small holes in the butterflies helps vacuum signal at idle for bigger camshafts (HP Books QJet book), but for a mostly stock engine it's an attempted bandaid for a bigger problem.
'68 GTO, 400/TH400, AC/PS/PB/PW/tilt, hideaways, Hurst dual gate
'72 442 'Vert, 350/TH350, AC/PS/PB/PW/tilt
'71 Javelin, 401/4-speed restomod
'74 Corvette, 383/4-speed, 450 hp, restomod *SOLD*
Jeff's Classics is offline
Rich fuel mix Red Devil Service, Maintenance and Technical Discussion 8 09-26-2010 09:15 AM
Hey Rich...injn37 Too Many Projects 1964-1974 Tempest, Lemans & GTO General Discussion 6 01-24-2010 03:44 PM
Jackpot!!! Woohoo!!! I'm Rich!!!!! Ricekiller The Lounge 5 10-06-2006 05:17 PM
LS1 Running Too Rich Groucho Service, Maintenance and Technical Discussion 28 07-18-2005 01:59 PM
