Question about battery (idiot) light - Pontiac GTO Forum
post #1 of 6 (permalink) Old 06-08-2012, 03:59 PM Thread Starter
rwhitaker's Avatar
The battery light in my '67 doesn't seem to come on correctly. It lights up when I turn the key to the left (to the Acc position) and it says on for the duration. Then when I turn the ignition to the on positon, nothing. Then when I start the car, the light flashes quickly and then goes off.
Can someone tell me if this is what I should be seeing? Seems as though it should be opposit of what I am seeing -- light should come on when the ignigion is turned on and stays lit until the alternator catches up and takes over for the battery.
Any help would be appreciated.
rwhitaker is offline
post #2 of 6 (permalink) Old 06-09-2012, 08:17 AM Thread Starter
rwhitaker's Avatar
Tested the voltage on my battery with multimeter. Motor running: 12.4. Motor running, lights on: 12.2. Looks like my alternator is bad. But would this give the battery light results noted above?
post #3 of 6 (permalink) Old 06-09-2012, 11:26 AM
Most parts stores will/can test the alt unit if you take it off the car. If it passes, I'd be looking towards the voltage regulator or the igition switch, they might be bad internally.
post #4 of 6 (permalink) Old 06-10-2012, 05:47 AM
A bad voltage regulator will also cause the output of the alternator to read low when the car is running. The "switch" that turns off the red light once the car starts and starts charging is inside the regulator.
post #5 of 6 (permalink) Old 06-11-2012, 12:52 PM Thread Starter
rwhitaker's Avatar
Thanks, guys.
Took alternator to AutoZone and it tested fine. Cleaned the connections, reinstalled, tightened belt and presto, it worked.
Would still like to know if the battery light is supposed to come on when ignition is turned to "on" position.
post #6 of 6 (permalink) Old 06-11-2012, 01:25 PM
Yessir it is. That's how you know the light is working and properly detecting that you've got an unbalanced "drain" on the battery.
"BRAKE" Idiot light injn37 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 06-07-2010 09:12 PM
When your battery was dead, did your battery light stay on? SueY816 2004-2006 GTO General Discussion 7 05-31-2010 05:54 PM
Battery Light teamwoody72 1964-1974 Tempest, Lemans & GTO General Discussion 2 07-26-2009 10:33 PM
Idiot light on after dead battery. vette68 Service, Maintenance and Technical Discussion 4 08-12-2006 07:08 PM
Idiot light in the Tach at the redline???? carbuff 2004-2006 GTO General Discussion 2 03-23-2005 07:33 PM
