question about posi differentials - Pontiac GTO Forum
post #1 of 12 (permalink) Old 12-20-2009, 08:15 PM Thread Starter
xcmac26's Avatar
Quoted: 5 Post(s)
My understanding of positrac rear diffs is that when the right wheel slips you get traction to the left. with a standard diff you get power only to the right. since i'm not sure what i've got, and i noticed something yesterday, i'm hoping for a bit of an explanation.
I threw the car into reverse while parked on some damp grass. Wheels slipped and when i pulled away i noticed two bare spots. will a standard differential send power to both wheels in reverse, or do i have a posi differential?
xcmac26 is offline
post #2 of 12 (permalink) Old 12-20-2009, 08:47 PM
It is possable to get both spinning with an open rear end, but it's rare and conditions would need to be just right. To be sure if you have an open or a posi, put one tire in the gravel/ice and one tire on the pavement, gun the throttle, if just the one tire spins it's an open, if both spin, it's a posi.
post #3 of 12 (permalink) Old 12-20-2009, 09:03 PM
66tempestGT's Avatar
with the standard open diff the wheel that spins is the one with the least resistance. the right tire spins most often because the rotation of the engine is trying to lift it up while pressing the left one down. if traction is equal either one or both can spin.
66tempestGT is offline
post #4 of 12 (permalink) Old 12-20-2009, 09:55 PM Thread Starter
xcmac26's Avatar
Quoted: 5 Post(s)
gravel and pavement, got it... will report back
xcmac26 is offline
post #5 of 12 (permalink) Old 12-21-2009, 08:53 AM
67 Basket Case Restorer
Too Many Projects's Avatar
Since the gravel/blacktop scenario gives you an excuse to spin the tires, you could just do a power brake too....
Of course that is harder on driveline components and if it is an open diff and only 1 wheel spins, you don't want to do that for long. The spider gears inside the carrier have no bearings to carry the load and with only 1 axle/side bearing spinning, it can over heat and cause damage to the gears and carrier. It's the Newtonian effect of a non-compressible fluid being forced out of the contact stress area due to non-forced circulatory lubrication.....
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #6 of 12 (permalink) Old 12-21-2009, 09:04 AM
Bobbyg's Avatar
Just jack up the rear end and spin the tires by hand.
non-posi should turn the opposite from each other.
jmo
Bobbyg is offline
post #7 of 12 (permalink) Old 12-21-2009, 09:13 AM
Phffffttttt........that's no fun, Bobby. He wants to mash the throttle, hopefully hear a tire howl and see smoke......
Mitch
1962 Impala SS
1938 Chev coupe
post #8 of 12 (permalink) Old 12-21-2009, 09:24 AM Thread Starter
xcmac26's Avatar
Quoted: 5 Post(s)
now THAT'S an answer I can understand
xcmac26 is offline
post #9 of 12 (permalink) Old 12-21-2009, 11:29 AM
Thank you............
Thank you very muuuuuuuuuuuch.......
Mitch
1962 Impala SS
1938 Chev coupe
post #10 of 12 (permalink) Old 12-21-2009, 12:12 PM
68greengoat's Avatar
Still waiting to hear about what diff you have. O'yeah, you're probably at work. Say, who's that looking over your shoulder??!!
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
'70 LeMans posi rear question bobj_70 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 10-23-2009 07:55 PM
carb /exhaust question. Lithium 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 6 06-05-2009 08:24 AM
how do i make a 12 bolt olds into posi skapegoat 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 3 02-10-2009 07:47 PM
convert open wheel to posi teamwoody72 1964-1974 Tempest, Lemans & GTO General Discussion 3 09-23-2008 07:53 PM
Newb nitrous question 05 GTO M6_Ashton Engine Discussions 3 09-27-2006 11:07 PM
