Rack N Pinion - Pontiac GTO Forum
post #1 of 8 (permalink) Old 11-11-2010, 07:47 PM Thread Starter
Rack N Pinion
Has anyone installed a Rack N Pinion steering on a 65 GTO. I would like to make the change and have seen one done which was at a Goodguys show at the Texas Motor Speedway. Ideas are appreciated.
KarLvr is offline
post #2 of 8 (permalink) Old 11-11-2010, 08:40 PM
Call Chris Sutton at Street Rod Garage.......I just posted some pics in the resto section, 67 GTO w/R&P.....Eric
Eric Animal is offline
post #3 of 8 (permalink) Old 11-11-2010, 08:47 PM
67 Basket Case Restorer
Too Many Projects's Avatar
Your chassis is custom made from scratch to utilize the r&p. Trying to install one on a stock frame and not have severe bump steer is near impossible. I've seen some for the A bodies and it's a strange animal that moves a bar back and forth in a cylinder to move the tie rods.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #4 of 8 (permalink) Old 11-11-2010, 08:54 PM
I've heard of the bump steer issues......personally, on a stock chassis, I would go with a "close ratio" steering box and some suspension upgrades.
post #5 of 8 (permalink) Old 11-11-2010, 09:02 PM
That's the best approach. Global West makes the best upper arms with their Delrin bushings but there are others that are comparable, such as Detroit Speed. You don't need to replace the lowers as there is no geometrical changes like the uppers. Just be sure to replace the lower bushings to match whatever is in the uppers.
Mitch
1962 Impala SS
1938 Chev coupe
post #6 of 8 (permalink) Old 11-13-2010, 06:58 PM
Quoted: 118 Post(s)
I'm not TOUCHING this one........
post #7 of 8 (permalink) Old 11-13-2010, 10:31 PM
Come on Jeff, let's help Karlvr spend all his money!!!!!!!
post #8 of 8 (permalink) Old 11-14-2010, 07:11 PM Thread Starter
Just starting this project and loving every minute........
KarLvr is offline
Rack and Pinion Parts mercdoc Drive train, suspension, alignment and brakes. 4 10-31-2010 11:28 AM
Rack and pinion in a 67? Need help bagged67 1964-1974 Tempest, Lemans & GTO General Discussion 6 03-22-2010 04:38 AM
rack question??? muscleT 2004-2006 GTO General Discussion 2 04-07-2008 03:33 PM
Tire Rack dustyminpin Wheels and tires 6 11-03-2007 01:46 PM
'04 GTO Rack and Pinion Leak=Fire Hazard rxdoc Service, Maintenance and Technical Discussion 9 03-09-2005 12:58 PM
