Radiator - Pontiac GTO Forum
post #1 of 21 (permalink) Old 09-24-2010, 06:05 PM Thread Starter
PisnNapalm's Avatar
Radiator
Ahhh!! I'm so pissed right now.
My new radiator arrived today. I had everything I needed to swap it in for the old one. Until... The farking transmission cooling lines would not unscrew from the old radiator.
I really don't want to take it to the shop for this problem, but I may not have a choice.
There are two choices listed in the Ames catalog and I have no idea which to order if I go ahead and just cut the old ones off. I dunno...
This was supposed to be an easy project... half an hour to an hour tops. Now... I'm just... grrrrr
EDIT:: I have a Turbo 400 transmission in it now.
PisnNapalm is offline
post #2 of 21 (permalink) Old 09-25-2010, 11:26 AM
allpawl66's Avatar
Cut them , remove rad. from car , heat them and remove , add a trans cooler if needed .
allpawl66 is offline
post #3 of 21 (permalink) Old 09-25-2010, 05:48 PM
Quoted: 118 Post(s)
I've had this happen a lot of times. The flared end of the tube becomes one with the connector. The solution is to use a tubing cutter and cut the lines. You can then: get new lines, or: flare the old lines with new fittings attached,(if the lines are long enough), or: install barbed brass male fittings in the radiator and splice the lines in with a short length of rubber trans line and clamps. Any of these methods will work...the rubber hose splice is the easiest, and is a reliable fix.
post #4 of 21 (permalink) Old 09-25-2010, 05:54 PM
My anal-ness would force me to get new lines where as any above suggestion is cheaper and will bet you back on the road sooner...!
Eric Animal is offline
post #5 of 21 (permalink) Old 09-25-2010, 06:01 PM
I would try heating up the nut that screws into the rad and tap it and try to loosen it with a line wrench......JB.
1964 GTO Hardtop.
2009 R/T Classic
2008 Chevy LTZ
Retired and taking it easy!
Jerry64 is offline
post #6 of 21 (permalink) Old 09-25-2010, 06:51 PM Thread Starter
PisnNapalm's Avatar
I have good news! The Liquid Wrench did it's thing and the lines came undone rather easily.
I still may need to get new lines though as I now have very minor fluid leaking from both connections into the radiator. It's like a drop every 5 minutes or so. I'm going to continue to drive it for now, though I will make sure to check my levels frequently.
Also, when I put fluid back into the transmission after the filter change, I did put in a bottle of Lucas Transmission Stop Leak. I'll see if that works it's magic and seals these up as well.
Lastly, I'm thinking about taking it to a local show tomorrow just for ****s and giggles.
EDIT:: Thank you all for your suggestions. I do appreciate the time you take to help out a stranger.
post #7 of 21 (permalink) Old 09-25-2010, 10:04 PM
hey wonderin if someone could help with my overheating problem with my 66 gto? It has a fairly new radiator and i changed the thermostat and flushed it and added all new coolant. The next time i took it out it overheated after idling for about 12 minutes on a cool day about 66 degrees. Is it the fan clutch?
wayne is offline
post #8 of 21 (permalink) Old 09-26-2010, 08:30 AM Thread Starter
PisnNapalm's Avatar
Update:: I ordered new upper and lower hoses as well as new transmission cooling lines. I checked the current hoses and they seem to be ok, but I just want new ones on the new radiator.
Wayne... Are you sure the new thermostat is working properly? Also, what motor do you have? Sometimes the lower hose can be sucked shut if it's worn out. That will restrict coolant flow as well.
post #9 of 21 (permalink) Old 09-26-2010, 01:47 PM
Don't forget to put the spring back in the lower hose so it don't collapse.....JB.
1964 GTO Hardtop.
2009 R/T Classic
2008 Chevy LTZ
Jerry64 is offline
post #10 of 21 (permalink) Old 09-26-2010, 02:12 PM Thread Starter
PisnNapalm's Avatar
I ordered a new one of those too. It was only $5 so I figured why not.
Looking into a new radiator tv66 1964-1974 Tempest, Lemans & GTO General Discussion 12 11-02-2009 10:59 AM
New radiator in developement. jpalamar Service, Maintenance and Technical Discussion 2 10-18-2009 03:39 PM
Radiator Defective? GTO4ART 2004-2006 GTO General Discussion 16 09-03-2009 11:59 PM
Radiator shroud Poncho Dan 2004-2006 GTO General Discussion 12 08-23-2009 11:25 AM
Need Radiator? btchplz Engine Discussions 11 02-21-2009 02:33 PM
