Now that I have buggered up my radiator drain plug.
Looking forward..........Im assuming (now) that the nut must be loosened CCW then the other part turned cw to drain?
thanks as always
I use a little neversez on the threads. First time I drained the radiator I could not loosen mine it was corroded. Replaced it with an AutoZone POS and found upon refilling the radiator the draincock was bad.... It worked fine before refilling.... Took the OEM one on the vise and opened it with vise grips wire brushed it well applied neverseze and it works swell now.
What pontiac said. It's freewheeling and it's done. Take the old one off and replace it. (or just loosen the shaft with vice grips and tighten it back up if you want to bugger it even more!!!!)
Says TK, as he dumps a bucket of Blue claws from the steaming pot onto the picnic table...then brings out the tub of ice packed with various frosty cold beverabes.....
Related Threads
Pontiac GTO Forum
514K posts
38.4K members
Since 2004
