radiator drain - Pontiac GTO Forum
post #1 of 12 (permalink) Old 07-10-2011, 02:50 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
radiator drain
Now that I have buggered up my radiator drain plug.
Looking forward..........Im assuming (now) that the nut must be loosened CCW then the other part turned cw to drain?
thanks as always
Topkat is offline
post #2 of 12 (permalink) Old 07-10-2011, 05:27 PM
66tempestGT's Avatar
turn the "T" part ccw to drain. cw to close.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
post #3 of 12 (permalink) Old 07-10-2011, 07:38 PM Thread Starter
Topkat's Avatar
sounds cool , except that the "T" is turning and just spinning
Topkat is offline
post #4 of 12 (permalink) Old 07-10-2011, 10:52 PM
get a new drain since the T has been broken by overtorquing.
pontiac is offline
post #5 of 12 (permalink) Old 07-11-2011, 08:42 AM
I use a little neversez on the threads. First time I drained the radiator I could not loosen mine it was corroded. Replaced it with an AutoZone POS and found upon refilling the radiator the draincock was bad.... It worked fine before refilling.... Took the OEM one on the vise and opened it with vise grips wire brushed it well applied neverseze and it works swell now.
post #6 of 12 (permalink) Old 07-12-2011, 10:11 PM
Quoted: 103 Post(s)
What pontiac said. It's freewheeling and it's done. Take the old one off and replace it. (or just loosen the shaft with vice grips and tighten it back up if you want to bugger it even more!!!!)
post #7 of 12 (permalink) Old 07-13-2011, 04:19 PM
CHANGE the petcock (proper name) and stop buggering things up....I'm getting carpal tunnel syndrome because of you! E
Eric Animal is offline
post #8 of 12 (permalink) Old 07-13-2011, 08:14 PM
jetstang's Avatar
That is the wrong part, that part is just a ****.. And belongs in a collection, cool NOS stuff, and funny.
Burning rubber since 1982!!
jetstang is offline
post #9 of 12 (permalink) Old 07-14-2011, 09:22 PM
Quoted: 103 Post(s)
We're ALL getting carpal tunnel, and Topkats hands are getting so beat up he can barely work the bottle opener.........
post #10 of 12 (permalink) Old 07-15-2011, 07:52 AM
Topkat, How did you make out???? E
Radiator BLK05GTO Service, Maintenance and Technical Discussion 5 10-21-2010 01:53 AM
Headlight delay / battery drain bforty Service, Maintenance and Technical Discussion 6 08-27-2010 10:41 AM
Magnetic oil drain plug Cobra126 Service, Maintenance and Technical Discussion 3 10-14-2009 10:57 AM
Where does the cowl drain? LastOutlaw 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 07-02-2009 12:42 PM
Need Radiator? btchplz Engine Discussions 11 02-21-2009 02:33 PM
