radiator fluid leak - Pontiac GTO Forum
post #1 of 6 (permalink) Old 05-23-2011, 06:10 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
radiator fluid leak
I have a radiator fluid leak. Less than a teaspoon in 24 hrs.
I put paper towels down and it is dripping from the center of the rear of the oil pan.(where the cork seal is) But there is no oil leaking. which leads me to believe it's "migrating" from elsewhere.
Looking around yesterday i found dampness under both of the hoses on the heater core and the fitting on the head that the short hose goes to.
I tightened them real good and now 24 hrs later I still have a leak.
(there was a tad under the top hose of the heater core but this hardly seems a likely source
There seems to kinda always be some on the rear of the valley pan.
But when I run my calibrated finger between the intake manifold and the upper edges of the valley pan I come up dry.
ps, the car has not been run in weeks
Any ideas?
Thanks as always
TK
Topkat is offline
post #2 of 6 (permalink) Old 05-23-2011, 06:18 PM
Check the heater hose nipple where it exits the right/rear head, also a couple other plugs that screw in in that imediate area.....E
Eric Animal is offline
post #3 of 6 (permalink) Old 05-23-2011, 06:24 PM
Quoted: 23 Post(s)
had similar leak...the press fit nipple that goes into the rear of the head on the passenger side will come loose sometimes if you have had them off and leak down in that vicinity. try a deep well socket over the nipple so it just contacts the edges at the base and give it a few taps then re-attach the hose and make sure to clamp it good and tight especially if your hose is a straight piece (factory hose had a molded bend) as to flex and make the connection it will pull at it and leak a bit on the backside.
Instg8ter is offline
post #4 of 6 (permalink) Old 05-23-2011, 07:22 PM
Quoted: 103 Post(s)
Topper, also check the thermostat gasket. Coolant can seep out, and it'll run down the center of the valley pan and end up at the back of the engine as you describe. From what you've said, my money is on the heater hoses/nipple.
post #5 of 6 (permalink) Old 05-26-2011, 06:49 AM
What kind of clamps are you using? Tower clamps while looking good and authentic can have issues. Every one I installed after putting engine back in had to be played with to stop leaking. Still the one on the lower radiator refused to cooperate.
post #6 of 6 (permalink) Old 05-31-2011, 10:43 AM
freeze plugs at rear of block are leaking. Common issue.
pontiac is offline
trans fluid Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 2 04-01-2011 04:20 PM
Radiator leak? firebird Engine Discussions 9 02-22-2011 08:36 PM
Tranny Fluid for and M6 YellO5LS2 Service, Maintenance and Technical Discussion 2 01-13-2011 08:32 PM
what brake fluid do you use roadracer Service, Maintenance and Technical Discussion 1 05-02-2006 03:54 PM
Synchromesh Fluid ModBoss2 Service, Maintenance and Technical Discussion 46 12-24-2005 08:46 AM
