radiator fluid leak - Pontiac GTO Forum
post #1 of 7 (permalink) Old 06-19-2011, 07:18 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
radiator fluid leak
still trying to track down my slight rad. fluid leak.
Im finding fluid on the rear top of the valley pan.
I put a piece of clean paper towel under the "nipple" on the rear of the passanger head.......
I know this piece is pressed in.
Also that there part of it is broken off.
If this turns out to be the culprit..........how much trouble is it to remove the dam thing and replace it?
It was rusted on the inside...then hot tanked,yet I know that if I start monkeying with it it will fragment.
ideas?
thanks as always
Topkat is offline
post #2 of 7 (permalink) Old 06-20-2011, 12:40 AM
Hey Top, looks like it's broken through the sealing "bead" around the top - and that's probably where your leak is coming from. Those things are pressed in, just like the block "freeze" plugs and can be replaced. They're getting "pricey" these days though, being as far as I know a Pontiac only item. I think I paid $50 + for one. Your idea about testing for the leak there sounds like a good one. If you find out that's where it's leaking from, then get yourself a replacement on-hand first, then you can drain the coolant (petcock on bottom of radiator) and use a hammer and cold-chisel to coax the old one out. Put a dab of sealant on the new one and finesse it in using a large socket on top of it and a mallet.
post #3 of 7 (permalink) Old 06-20-2011, 05:38 AM
Pressure test it with one of those Stant kits, you can rent them at almost any parts store. GL.
post #4 of 7 (permalink) Old 06-20-2011, 08:05 AM
with both......
Eric Animal is offline
post #5 of 7 (permalink) Old 06-20-2011, 05:01 PM
Quoted: 100 Post(s)
Ames has them for $28. I agree with the above posts. Hard to remove, but easy to put the new one in.
post #6 of 7 (permalink) Old 06-21-2011, 09:06 AM Thread Starter
Topkat's Avatar
Thanks guys, but I just dont have evidence of a leak there.
I do have a small pool of rad fluid on the rear top of the valley pan.
where else could it be comming from?
dosnt seem to be the thermostat.
ps, im not running the motor so nothing's circulating
thanks as always
Topkat is offline
post #7 of 7 (permalink) Old 06-21-2011, 02:30 PM
Quoted: 100 Post(s)
If it's not the T-stat and not the nipple it could be the intake manifold at the front passage. Take a dental mirror and a flashlight and some white toilet paper or a paper towel and check it out. Could also be the front seal between the timing cover and intake, but usually these leak all over the timing cover........
radiator fluid leak Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 5 05-31-2011 10:43 AM
Radiator leak? firebird Engine Discussions 9 02-22-2011 08:36 PM
Fluid Servicing? symbian Service, Maintenance and Technical Discussion 5 04-04-2010 09:21 PM
tranny fluid v8newb Service, Maintenance and Technical Discussion 0 02-28-2009 02:52 PM
what brake fluid do you use roadracer Service, Maintenance and Technical Discussion 1 05-02-2006 03:54 PM
