ram air cable connection help - Pontiac GTO Forum
post #1 of 5 (permalink) Old 11-11-2014, 12:10 PM Thread Starter
I have a 1969 GTO Ram Air IV. I installed a new flapper door assembly for the ram air (never had the original). I don't know how to connect the upper ram air cable to the flapper door. The flapper has one round hole that appears to be where the cable would connect. I purchased a new upper cable, so I have the end of the cable and a round hole in the flapper, there must be something to connect the two?
waterfire69 is offline
post #2 of 5 (permalink) Old 11-12-2014, 12:49 AM
Not sure they are the same,but in my 70 RA 3 the end of the cable is shaped like an elongated 'z' and that fits in the hole and provides the connection. Make sense?
J-
Jjkra is offline
post #3 of 5 (permalink) Old 11-12-2014, 05:00 PM Thread Starter
Yes that makes sense, my cable is similar, however when I put it in the hole it doesn't stay, like the hole is too big.
post #4 of 5 (permalink) Old 11-13-2014, 07:55 AM
Changing the size of the hole should not be much of a problem then. Right?
J-
Jjkra is offline
post #5 of 5 (permalink) Old 11-13-2014, 02:31 PM Thread Starter
The part the hole is in is plastic. Any idea how to make the hole smaller?
70 gto non ram air to ram air 1970gto455conv 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 09-05-2014 05:12 PM
Ram Air III cable adjustment blooney 1964-1974 Tempest, Lemans & GTO General Discussion 1 08-01-2014 03:34 PM
can you turn the ram air hood into a functional ram air? court_jester06 Intake and Exhaust Discussions 12 07-25-2010 01:36 PM
Ram Air III cable question... 70Judge 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 01-05-2010 06:36 PM
ram air throttle cable bracket my1971gto4spd 1964-1974 Tempest, Lemans & GTO General Discussion 2 05-22-2006 11:03 PM
