Ram air tube - Pontiac GTO Forum
post #1 of 6 (permalink) Old 08-28-2018, 06:27 PM Thread Starter
Quoted: 13 Post(s)
Ram air tube
Hi,newbie here.I'm looking at a 1970 gto ram air,the one that has a manual knob on the dash.
But on driver side the port out on air cleaner that would be fed by warm air input is capped off,
And the port it would connect to is open,no hose connecting these two.
Is this ok?
I appreciate any input,again I'm new with gto"
Thanks,
Bob H
rheckman is offline
post #2 of 6 (permalink) Old 08-28-2018, 07:53 PM
Quoted: 349 Post(s)
Is this ok?
Thanks,
Bob H
Pictures please.
post #3 of 6 (permalink) Old 08-28-2018, 08:03 PM Thread Starter
Quoted: 13 Post(s)
Here it is,
rheckman is offline
post #4 of 6 (permalink) Old 08-28-2018, 08:46 PM
Quoted: 349 Post(s)
Here it is,
OK, here is what I have, "The RA IV had 2 pre-heaters, one on the left side and one on the right. The RA III had only the 1 pre-heater on the left hand side." I see you have the shroud on the exhaust manifold. A pre-heat tube/duct then went up to what looks like a 90 degree plastic elbow that goes into the hole at the bottom of the base.
Someone must have blocked yours off to keep heat from going into the set-up to keep it cooler - makes sense to me, I'd probably do the same thing.
post #5 of 6 (permalink) Old 08-28-2018, 09:30 PM Thread Starter
Quoted: 13 Post(s)
Ok,the car is in Florida,makes sense.
Thanks for the quick response.
Reg's,
Bob H
rheckman is offline
post #6 of 6 (permalink) Old 08-30-2018, 07:02 PM
Quoted: 349 Post(s)
Just to follow up, I have saved these pics for reference and in the pics of the engine, you can see the heat tubes that are used on the RA IV engine, one on each side. The RA III will only have the drivers side attached.
Name:	03  Black RA IV - engine bay restored.JPG
ID:	115153   Click image for larger version
Name:	04 Black RA IV -engine bay restored.JPG
70 gto non ram air to ram air 1970gto455conv 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 09-05-2014 05:12 PM
can you turn the ram air hood into a functional ram air? court_jester06 Intake and Exhaust Discussions 12 07-25-2010 01:36 PM
1971 - 72 GTO Ram Air air filter slickman 1964-1974 Tempest, Lemans & GTO General Discussion 1 10-19-2006 08:44 PM
