Real simple question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-28-2019, 07:54 PM Thread Starter
Quoted: 12 Post(s)
Took my goat out after 12 years and the valve covers leak, bought new ones today and can remember.... Do you use gasket sealer on them ? Thanks so much
keiko is offline
post #2 of 3 (permalink) Old 04-28-2019, 08:58 PM
Quoted: 348 Post(s)
It can be optional. It would not hurt to put a little on the valve cover side to keep the gasket in place. Make sure you flatten out the bolt through holes on the valve cover if they have been over tightened. If they are dimpled down, they will not clamp the gasket well enough and you will have leaks.
post #3 of 3 (permalink) Old 04-29-2019, 01:21 PM
Quoted: 98 Post(s)
What Jim said. Be sure to peen the cover rails straight. I always use a couple of dabs of grease to hold the gasket to the valve cover. I hate removing sealer from those old covers. I usually install mine with a nut driver or a 1/4" drive short ratchet. Just snug. Re-torque them after a couple of weeks.
simple question. New2thefamily Intake and Exhaust Discussions 2 10-09-2009 04:24 PM
New owner with simple muffler question Tower Intake and Exhaust Discussions 4 10-13-2006 10:28 PM
simple question tommycheng1728 Wheels and tires 1 02-10-2006 08:37 PM
New Owner/ New Member but a simple question edysinger 2004-2006 GTO General Discussion 19 12-02-2005 09:19 PM
Simple Question Phantom33 2004-2006 GTO General Discussion 6 10-25-2004 08:13 PM
