rear end gear - Pontiac GTO Forum
post #1 of 6 (permalink) Old 09-19-2018, 11:06 AM Thread Starter
rear end gear
I have a 1964 GTO 389 tri power with a Muncie 20 close ratio 4 sp. I have 4:11 rear end. can I drop to 3:56 or 3:36 to lower my rpm?
julie128 is offline
post #2 of 6 (permalink) Old 09-19-2018, 11:23 AM
BLK69JUDGE's Avatar
Quoted: 57 Post(s)
Welcome
welcome
a few questions arise ........
I am no expert .. but been around these cars for 40 years....
is the differential the original 10 bolt ? 411 sounds chevy ish we had 390 and 433
yes a gear change is a great way to lower rpm
but
if you do have a close ratio m 21 going lower than 355 the ratio between 1st gear and
the differntial makes for a chattery clutch and lack luster performance off idle
and starting on a hill ... well ... its not fun ...or easy on clutches...
if its an m20 wide ratio alot better .... for the 336 ratio
355 and close ratio I dont think ever came together in our gto's
closeratio needed a 390 gear to get rpm's up
there is alot of good info here .....
ole pinion should chime in ,,, I havent seen him on in a while .. hopefully hes fine ..
basically you need to know for sure what your first gear ratio is
for starters probably a 325 case close ratio and 390 gears
even wide ratios with the lower first and second gears and 355 wind out pretty good
with the stock 14" tires ..... whats your rpm on the freeway at 60 and tire size ??
is it an aftermarket or original tach .... many original tachs need calibrated and repaired
DO NOT TRUST AN ORIGINAL TACH for accuraccy until you have put a known modern one
hooked up along side to compare on a run around the block.....
these are just my opinions and insight from tinkering on over 100 pontiacs in my auto maintenence life
welcome aboard
ScottT
BLK69JUDGE is online now
post #3 of 6 (permalink) Old 09-19-2018, 01:28 PM
Quoted: 98 Post(s)
If an 8.2 ten bolt (stock) you can drop in gears as low as 3.36. I did it with my '65 28 years ago and it transformed the car. Go for it.
post #4 of 6 (permalink) Old 09-19-2018, 03:14 PM
Quoted: 55 Post(s)
"...411 sounds chevy ish we had 390 and 433..."
Yeah, the 3.90 & 4.33 was available from the factory. But, there have been aftermarket 4.11 gears for the 8.2" BOP.
Here's some 4.11's at Summit.
https://www.summitracing.com/parts/m...2411/overview/
Here's some cheap ones on Ebay.
https://www.ebay.com/itm/GM-8-2-BOP-...-/370875730118
So, the car in question could easily have aftermarket 8.2 BOP 4.11 gears.
"...can I drop to 3:56 or 3:36 to lower my rpm?..."
3.36 & 3.55 gears are still sold new.
The factory 8.2" BOP rears had a cover like shown in the pic below.
Name:	8.2 BOP .jpg
bigD is online now
post #5 of 6 (permalink) Old 09-19-2018, 05:30 PM
the65gto's Avatar
Quoted: 12 Post(s)
Mine came with 3:55 as stock, still to much rpm for highway ([email protected]). Found a 4:11 and took quite a while to swap it in and get the spacers correct etc, but once done the swap was easy, new crush washer everytime, about 1.5 hrs. Used the 4:11 while at the drag strip, 3:55 for every thing else.
the65gto is offline
post #6 of 6 (permalink) Old 09-20-2018, 07:19 PM
336
I have 336 gear in my 64 ,4 spd and I am pleased with them . I have found that original GM gears were less likely to whine than aftermarket sets . JMO
bigblock is offline
'67 GTO rear end gear ratio change 67gtoconv 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 04-19-2014 11:47 AM
Speedometer Drive Gear and Driven GEAR timmyg 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-05-2012 03:48 PM
**Help** Rear End Gear Ratio 1967 Goat Oldsmobileman 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 06-10-2010 12:21 PM
rear end gear ratio question matt68gto 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 04-03-2006 10:30 AM
Rear End Gear ? KERLS04 2004-2006 GTO General Discussion 3 03-28-2005 09:33 AM
