rear end gear source - Pontiac GTO Forum
post #1 of 5 (permalink) Old 09-19-2018, 11:45 AM Thread Starter
Where is a good source for rear end gears for 1964 GTO?
julie128 is offline
post #2 of 5 (permalink) Old 09-19-2018, 01:29 PM
BLK69JUDGE's Avatar
Quoted: 57 Post(s)
well
theres a following for different brands and you should get a great response
some have awhine ... sometimes your builder has a preference. ...
but
I just happened to have a SWEET set of GM 68 336 gears
from a 68 gto rear diff ... 44000 mile originals that are very nice
250 shipped
open original carrier and mint open spider gears available also 100
Scott
[email protected]
ID:	115509   Click image for larger version
ID:	115511   Click image for larger version
ID:	115513   Click image for larger version
BLK69JUDGE is online now
post #3 of 5 (permalink) Old 09-19-2018, 02:39 PM
Quoted: 55 Post(s)
Yeah, 8.2 BOP gears are available from Summit, Jegs, most all the online rear end shops, Ebay sellers, and many other places.
And, like most other parts, there are different brands, with varying prices. One of the higher priced brands that have had a good rep for many years is the Richmond brand.
Looks like Summit sells 3 brands.
https://www.summitracing.com/search/...iew=Horizontal
Here are Elite & Yukon brands.
http://www.ronsmachiningservice.net/gm-8-2-bop/
This Ebay seller has the cheapest rear end parts I've seen online. I assume these cheap parts are all made in China. Not saying they're good or bad, just posting that they are a source for 8.2 BOP rear end parts.
https://www.ebay.com/itm/GM-8-2-BOP-...4AAOSwstxVQTDl
You can also order direct from them. Here's some Yukon 3.36 gears, for $241 shipped.
https://www.quickperformance.com/YG-...6_p_18708.html
bigD is offline
post #4 of 5 (permalink) Old 09-28-2018, 01:37 PM
Quoted: 98 Post(s)
In my experience, the original GM gears can't be beat for quality and quiet running. I'd be inclined to install an original used set of gears, if they were in excellent shape. My 2 cents....
post #5 of 5 (permalink) Old 06-01-2019, 07:03 AM
Mike O誰eill's Avatar
I just purchased Yukon Gear part number YG GMBOP-336 gear set from Summit, for my 67 GTO. I chose this one because in the question & answers in the listing it said made in USA. Got the product and the box says made in China. Also, the ratio is 44:13 (3.38), unlike the original GM gears which are 37:11 (3.36).
1967 Pontiac GTO 400, TH400 transmission
Mike O誰eill is online now
rear end gear julie128 1964-1974 Tempest, Lemans & GTO General Discussion 5 09-20-2018 07:19 PM
'67 GTO rear end gear ratio change 67gtoconv 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 04-19-2014 11:47 AM
**Help** Rear End Gear Ratio 1967 Goat Oldsmobileman 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 06-10-2010 12:21 PM
rear end gear ratio question matt68gto 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 04-03-2006 10:30 AM
Rear End Gear ? KERLS04 2004-2006 GTO General Discussion 3 03-28-2005 09:33 AM
