Rear upper control arms - Pontiac GTO Forum
post #1 of 4 (permalink) Old 02-13-2016, 03:15 PM Thread Starter
maktope's Avatar
Any trick to get these things off. Or just more muscle? Can't get either side loose
maktope is offline
post #2 of 4 (permalink) Old 02-13-2016, 04:43 PM
Wendt69's Avatar
Quoted: 5 Post(s)
I just recently took my diff out along with the upper and lower control arms.
Use lots of penetrating oil, the longest
Wrench you have and LOTS of muscle. Just get hard on them you'll get em'.
Wendt69 is offline
post #3 of 4 (permalink) Old 02-13-2016, 06:12 PM
Quoted: 106 Post(s)
PB Blaster and an impact gun.
Goat Roper is offline
post #4 of 4 (permalink) Old 02-14-2016, 09:47 AM
Are we talking about getting the bolts loose or getting the arms out after you do?
If we're talking bolts, leverage and a good penetrant are your friends. The longer the wrench, the better. If you don't already have one, a good electric (or air if you have an air system) impact is a sound investment.
It also helps if you can get the car up in the air good, and use a floor jack to support the axle so you can move it up and down to take some of the load off of the bushings.
And just in the interest of safety, in case you haven't already, make sure you disconnect the shocks and drop the axle down far enough to remove the coil springs. If you do manage to get one of the arms out with the coil springs still installed, very bad things are likely to happen.
Torque specs for rear upper/lower control arms calray 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 6 12-04-2015 12:07 AM
Getting ball joints into upper control arms. SlamminGears65Goat 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 06-22-2012 09:23 PM
Upper control arms in backward? Topkat 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 10-25-2010 06:19 PM
Rear control arms HenryJ63 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 05-03-2010 08:03 PM
